944 tranny to 924
bradito
PostPosted: Tue Aug 28, 2012 12:29 pm    Post subject: 944 tranny to 924 Reply with quote
Anyone ever tried to put an early 944 tranny in a 924? So far this seems to be the most feasible solution for my woes. The donor car it's an 85.5.
1981 931
PostPosted: Tue Aug 28, 2012 9:45 pm    Post subject: Reply with quote
Yes, BTDT, some gears are a touch tall, but works well otherwise. Pretty sure we wrote this up a few times...
bradito
PostPosted: Wed Aug 29, 2012 3:09 am    Post subject: Reply with quote
Awesome. Thanks!
1981 931
PostPosted: Wed Aug 29, 2012 4:12 am    Post subject: Reply with quote
Isn't there a shaft diameter difference? I seem to remember Ideola hammering on me about that before....
I think the 924 turbo and the 944 share the same shaft diameter, but the 924 NA and the 944 do not.
The 924S and 944 also share the same shaft, but then the 924S is just a 944 in a slinky dress
So I think you'd have to swap the clutch disc and torque tube or swap the input shaft of the 944 trans.
PostPosted: Wed Aug 29, 2012 4:29 am    Post subject: Reply with quote
Yes, there is a drive shaft diameter difference between the 924 NA and the 2.5L cars. If I remember correctly, the input shaft on the 924NA Audi-based trans is also shorter, meaning that you can't easily make a coupler adapter either. The one sure way to make this work is to replace the 924 torque tube with the 944 torque tube, and then install a Bronco II clutch disc, which can be run with the NA cable operated setup without requiring the entire hydraulic clutch setup found in the 931 and later 2.5L cars.
PostPosted: Wed Aug 29, 2012 5:18 am    Post subject: Reply with quote
Exactly - use the 944 torque tube, Bronco II clutch disc, and you'll also need the shift rod from the 944 if you're putting it in a (formerly) 4-speed 924.
bradito
PostPosted: Fri Aug 31, 2012 11:24 am    Post subject: Reply with quote
The clutch from a freakin' ford bronco!? That's hilarious. There is some info in the tech section of 924.org as well and it seems to indicate that I will also need the mounts and a crossmember for the torsion bars in addition the shifter and linkage... Thanks for the knowledge guys. You rule! Oh and btw it is currently a 5-speed if that affects anything. Well at least now I know it is doable.
1981 931
PostPosted: Fri Aug 31, 2012 10:13 pm    Post subject: Reply with quote
No, you won't need to change any mounts etc - it's a bolt-in.
But what's wrong with the 5-speed? Consider rebuilding? Gearing will be better...
