B
Posted: Thu Sep 20, 2012 8:46 am Post subject: problem at 4000rpm - ? |
hey everyone,
Things seemed to be going a little better driving-wise lately. However (there always seems to be a however ) I noticed an intermittent popping. It was slight and not very loud or pronounced. So I did not think much of it - everything else seemed pretty good.
When I was driving the last few times, I noticed a hesitation at about 3500 when cruising- I could accelerate through it. At other times, when accelerating to 4000 (in any gear but 5th) it seemed to hit a wall. It was hesitating and almost choking. When I would shift, it was fine until I accelerated up to 4k again.
Could this be a fuel issue? Or something internal?
Any thoughts or ideas are greatly appreciated.
thanks
Sean _________________ 1979 924 n/a
BAE turbo
5-speed snailshell |
staticsan
Posted: Thu Sep 20, 2012 9:33 am Post subject: |
There was a recent discussion about the rev curve and someone commented that the shape of the venturi and the compromises inherent in a mechanical system means the engine tends to run a little lean in the middle of the range. You could make the mixture a little richer and see if the problem goes away. And by "a little", I mean no more than 1/8th of a turn at a time.
Wade. _________________ '82 British NA - Which I think I've been very lucky with! |
B
Posted: Thu Sep 20, 2012 10:16 am Post subject: |
Thanks Wade - I will give that a try -
I was afraid I might be running out of fuel. I was thinking about checking my system pressure also - do you think that may also be a concern?
thanks again
BAE turbo
Posted: Thu Sep 20, 2012 3:04 pm Post subject: |
You could have a clogged fuel filter, or maybe even a faulty fuel line that is restricting fuel flow. _________________ 78 924 NA
5-lug |
B
Posted: Fri Sep 21, 2012 2:56 am Post subject: |
I did just get a new fuel filter for the spring - I'll try that now as well.
Faulty fuel line - as in corroded? Is there a good check for that - maybe blow air through the line? after disconnecting the fuel accum.?
does that sound right/ok?
thanks very much everyone!
BAE turbo
Posted: Fri Sep 21, 2012 3:07 pm Post subject: |
Fuel flow test will determine if you have a clogged filter or problem fuel line. I don't think blowing air through would be a good way to test it. _________________ 78 924 NA
5-lug |
xr4outcast
Joined: 26 Apr 2007 Posts: 67 Location: Annapolis, Maryland
Posted: Thu Dec 06, 2012 4:11 am Post subject: |
Was this problem ever resolved? I'm having the exact same problem. _________________ So many cars so little time. |
