transmission cooler
leadfoot
PostPosted: Mon Jan 07, 2013 7:47 pm    Post subject: transmission cooler Reply with quote
just wondering if anyone has installed a cooler on the transmisson is wanting to share some install details such as
pump location, flow capacity and line sizes
line locatons
thermostat used and temp setting?
I have a spare 931 oil cooler and am thinking if this would be suitable to use for the G31 trans, at the moment it has the stock lines with banjo fittings
cheers
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Tue Jan 08, 2013 3:02 am    Post subject: Reply with quote
I'd say this would be a good start:
http://www.patrickmotorsports.com/part/pkg-trans-oil-cooler-kit/
Since the G31 is related to the Porsche 901/915 transaxles.
The Tilton pump is a pretty common piece as are the rest of the pieces, so I'd look at the pump they use, etc.
I suspect the oil pickup is from the drain port and the return is into the fill port, but I don't know for sure.
