Arvidw
Joined: 20 Sep 2009 Posts: 227 Location: The Nederlands (Europe)
Posted: Mon Dec 17, 2012 12:47 am Post subject: Engine knock detection |
Today I installed a VW knock sensor on my 924. It is connected via the microphone port on my laptop to some headphones. The sensor is bolted to the cast iron engine block on one of the mounting points of the steel coolant return pipe. (the one closest to the center of the engine)
I find it quite amazing what sound you can hear without the engine running, a squeaking clutch lever, the shifter mechanism in the transmission, the thottle valve opening and closing, injectors firing in test mode. It really does give a very nice and clear sound.
However with the engine running the only thing I can hear is valve train noise, from 1000-6000rpm I can only hear the clattering of tappets and valves.
Has anybody got any experience with audible knock detection on a porsche 924 2.0? If so, what did you use, what did hear, up to which engine RPM where you able to hear engine knock? _________________ Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl) |
Posted: Tue Dec 18, 2012 5:07 am Post subject: |
Just bought myself a KS-4. The pro kit (which a mate has) allows you to listen in for knock whilst tuning. Once set the KS-4 will warn if knock starts http://www.phormula.co.uk/
Where did you bolt your sensor? _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Tue Dec 18, 2012 5:36 am Post subject: |
I've purchased but not yet installed a Knocksense (http://www.viatrack.ca/) after reading several posts on the topic. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Tue Dec 18, 2012 7:17 am Post subject: |
OT:
Put a knock sensor on the Benz a couple years ago. Got it calibrated to the data AQ (not hooked up to control advance) and went out for a few laps. About 5 laps in, the engine threw a rod out of the block right where the knock sensor was mounted. Later the knock sensor data showed all normal until a massive spike and then flat lined.
Arvidw
Posted: Tue Dec 18, 2012 7:24 am Post subject: |
The sensor has been placed here:
@Carrera RSR, Have you already spend time tuning your 924 with the KS-4 Analyser? If so, how did you do that? Advance ignition and do a 2000-7000rpm run and listen for detonation, if not, advance even more?
@Ideola, Are you going to use the knocksense in combination with a EFI controller (Megasquirt?) or are you going to use the LED indication for tuning your engine? _________________ Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl) |
Posted: Tue Dec 18, 2012 8:06 am Post subject: |
My engine is still being built so no experience of tuning yet.
I was interested in the position of the sensor as that lug is an option but my fear its too low. The sensor needs to be as close to point of combustion as possible. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Tue Dec 18, 2012 8:43 am Post subject: |
| Fifty50Plus wrote: | OT:
Chuck |
Sounds like the failure wasn't knock-related, but was just due to a failure of the rod (bolt/nut/cap, etc) So, yeah knock-detection won't save you from everything as stuff can still go "FUBAR" unexpectedly.
I agree that the knock sensor should be closer to the combustion chamber. Many manufacturers mount them on the intake manifold for this reason (my turbo car for one). _________________ Stefan
Posted: Tue Dec 18, 2012 9:32 am Post subject: |
| fiat22turbo wrote: | | Sounds like the failure wasn't knock-related, but was just due to a failure of the rod (bolt/nut/cap, etc) So, yeah knock-detection won't save you from everything as stuff can still go "FUBAR" unexpectedly. |
Fiat - agreed. Just thought it was ironic that we were able to capture an unrelated failure the moment we put on more data acquisition.
WE were going to eventually make some electronic timing advance changes to see if we could induce knock and detect it. Wound up totalling the car before we went forward with further knock sensor testing. We will attempt to transfer the tech stuff to the 924 as we build it.
WEASEL149
Joined: 19 Aug 2005 Posts: 595 Location: UK, Sheffield
Posted: Thu Dec 20, 2012 2:49 am Post subject: |
A few others (Cedric?) have used the other lug between 3 and 4 which you can see near the crankcase breather in that photo. That's where mine is going.
When tuning, it's advisable to use electronic filtered detection and also listen on headphones/detcans. The human ear is a much more accurate 'device' provided you know what knock/detonation sounds like. _________________ 1979 UK 932 |
Posted: Thu Dec 20, 2012 3:41 pm Post subject: |
| WEASEL149 wrote: | A few others (Cedric?) have used the other lug between 3 and 4 which you can see near the crankcase breather in that photo. That's where mine is going.
When tuning, it's advisable to use electronic filtered detection and also listen on headphones/detcans. The human ear is a much more accurate 'device' provided you know what knock/detonation sounds like. |
I use that boss, correct, looks kind of good compared to the recommended location in the bosch automotive handbook. Together with a turboxs knocklite, which does some kind of simple noise calibration curve. Works really well could sense knock long before you could here anything. Since I change a faulty ignition module and wur (ran lean according to wb) ive never had any problems since. Best engine investment yet:-) _________________ 1980 924 Turbo
Posted: Thu Dec 20, 2012 10:24 pm Post subject: |
Have you fitted the sensor using the engine mounting bolt?!
Would the boss under the manifold just above the oil filter housing be better located? Its nearer the top of the pistons at TDC. Would it be too harsh an environment for heat for the sensor and cabling, bearing in mind my temps should be circa 30% less with the ceramic coatings I've used on the latest build
Arvidw
Posted: Fri Dec 21, 2012 5:08 am Post subject: |
@Weasel and Cedric, I'll try that point the next time. I have to fabricate some M10 to M8 bolt as my sensor only accepts M8. As it is probably a much better position it is worth the time and effort.
@Carrera RSR, that would indeed be a very nice spot to place the sensor. It is too bad it is so difficult to reach
I recorded the sound of my engine today. I tried to introduce engine knock by advancing the ignition drastically in only one load bin in my IGN table.
Video: http://youtu.be/rdEVSZz0n8E
I could really feel the engine struggling around 3300rpm however I can't really hear detonation around 3300rpm in the sound clip. However in the beginning of the clip just 2 seconds after opening the throttle I do hear some strange rattling noises so I'm wondering wetter that is detonation? _________________ Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl) |
RC
Posted: Fri Dec 21, 2012 8:37 am Post subject: |
You may find some useful info in this old thread Arvid:
http://www.924board.org/viewtopic.php?t=22379 _________________ World`s quickest 924 2L slushbox
ksis
Posted: Fri Dec 21, 2012 9:13 am Post subject: |
I thought a knock sensor should be placed on number one piston at the middle of the stroke. Check the placement of a sensor on a MK2 VW 1.8. _________________ 77 924
64 Spitfire
76 TR6
04 Jetta
77 Schwinn Scrambler
Awsome pair of Chucks
http://www.cardomain.com/id/ksiskin |
Posted: Fri Dec 21, 2012 9:41 pm Post subject: |
Well that was 4 pages of hot air and 20 minutes of my life I will never get back! As usual no conclusion. Just multiple opinions. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
