Ground "Crown"
PostPosted: Tue Mar 12, 2013 2:07 pm    Post subject: Ground "Crown" Reply with quote
Anyone got a source for those crazy crowns of male spade terminals like up under the toofah dash?
PostPosted: Wed Mar 13, 2013 12:50 am    Post subject: Reply with quote
Found a 4-terminal ground point: 171971519A, should be 4 or 5 bucks from PCNA.
PostPosted: Wed Mar 13, 2013 2:29 am    Post subject: Reply with quote
Not sure what you're doing but I wonder, couldn't you just make a medusa pigtail out of a bunch of males soldered together with an eye that you screw to the ground?
PostPosted: Wed Mar 13, 2013 3:11 am    Post subject: Reply with quote
Making an aux underdash ground in the Pro44 car. Kens_911s is sending me the stock 8-connector piece, which has a central hole that will go over an aftermarket terminal lug. I'll post a pic when it is together.
BUT. . .curious about your suggestion but don't completely understand? Could you elucidate?
PostPosted: Sun Mar 17, 2013 7:29 am    Post subject: Reply with quote
Perfect. Factory piece is sweet.
the_mad_electrician
PostPosted: Sun Mar 17, 2013 8:05 am    Post subject: Reply with quote
That thing looks like a torure device.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
