master cylinder piston removal
kylekev
PostPosted: Sat Mar 30, 2013 6:58 am    Post subject: master cylinder piston removal Reply with quote
I am rebuilding the master cylinder on a 1978 924 because we keep getting air into the brake lines. I am following the steps in the Haynes manual and have removed the retainer ring and and retaining bolt. Cannot get the piston to pull out. Am I missing something on pulling the piston out of the body?
PostPosted: Sat Mar 30, 2013 8:29 am    Post subject: Reply with quote
The first washer after the retaining ring will be stuck in the retainer rings groove. Pull harder!
kylekev
PostPosted: Sat Mar 30, 2013 8:37 am    Post subject: Reply with quote
I guess it does not matter if I damage the "piston rod" because it is being replaced. Correct?
kylekev
PostPosted: Sat Mar 30, 2013 8:52 am    Post subject: Reply with quote
never mind. I put the "piston rod" in a vise and pulled harder. and it popped out.
Thanks.
