RedChar
Joined: 31 Dec 2010 Posts: 32 Location: Pittsburgh, PA
Posted: Thu May 02, 2013 5:06 am Post subject: Head Gasket replacement tips |
I've got oil in the coolant, but not vice versa and I already replaced the oil cooler rings/gaskets. Which means... HEAD GASKET TIME!!!
Before I delve into this I was just wonder if anyone has any tips/suggestions. I've already read (and will be using as a reference) Clark's Garage. I am weeping at the fact I may have to break down and buy the belt tension tool, but if I need it, I need it. _________________ '87 924s - Haven't come up with a good nickname
'07 - MINI Cooper, base
'85 - Mercedes 300td LeMons veggie oil car - The Frau |
Posted: Thu May 02, 2013 9:14 am Post subject: |
Be sure and do a vacuum refresh while you have the manifold off, and certainly refresh the head itself. Clean ground post at the rear of the manifold, too. . .and maybe a new heater valve. Service and flow test radiator.
Also, don't skimp on FOES. Balance shaft seals and front bearings, balance shaft sleeves, front main seal and crank sleeve, water pump with new hardware kit, new timing belt tensioner stud. Update power steering feed hose and replace reservoir.
Zim's has good FOES kits. _________________ Toofah King Bad
skytrooper
Joined: 29 Aug 2007 Posts: 461 Location: Canandaigua, NY
Posted: Thu May 02, 2013 11:02 am Post subject: |
+1 on Zim's. That is where I bought my FOES kit from and wasser pump. _________________ Matt
1987 - 924S "Black Pearl"
1982 - BMW 633CSi
1984 - BMW 528e
1976 911S Targa (Gone) |
RedChar
Posted: Fri May 03, 2013 2:10 am Post subject: |
Rasta, great suggestions, exactly what I was looking for! And thanks for the pointer to Zim's. _________________ '87 924s - Haven't come up with a good nickname
Posted: Fri May 03, 2013 6:32 am Post subject: |
Not to hijack the post, much, but my '88 has 78K miles on it and am pulling the engine for the FOES and a clutch job (Paul, Scotch, and me). Question, is it worth replacing the suspect rod bearings at the same time? This car is going to be a 944Spec car eventually, so mucho track time. Hopefully. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Fri May 03, 2013 8:30 am Post subject: |
Dave...Dave...Dave _________________ 1979 924 NA race car H-Prod SCCA
Posted: Fri May 03, 2013 9:35 am Post subject: |
| Grenadiers wrote: | | Question, is it worth replacing the suspect rod bearings at the same time? This car is going to be a 944Spec car eventually, so mucho track time. Hopefully. |
 _________________ Stefan
Posted: Fri May 03, 2013 9:43 am Post subject: |
Posted: Fri May 03, 2013 9:43 pm Post subject: |
Doh! Guess that means a 'yes'~! _________________ '83 944 Track car.
John_AZ
Joined: 25 Jun 2008 Posts: 130 Location: Arizona ~Carefree Highway~
RedChar
Posted: Sun May 19, 2013 9:50 am Post subject: Re: Head Gasket replacement tips |
That is a huuuuge difference in price! Thanks for the link! Anyone have experience using one of these or an earlier version? _________________ '87 924s - Haven't come up with a good nickname
Posted: Sun May 19, 2013 2:51 pm Post subject: |
| Grenadiers wrote: | | Doh! Guess that means a 'yes'~! |
You're not drinking that scotch already, are you? _________________ White 87 924S "Ghost"
