Air conditioning help
kcoyle
PostPosted: Mon Jun 10, 2013 10:36 pm    Post subject: Air conditioning help Reply with quote
I think I'm going to at least troubleshoot my A/C system and I'm looking for some specs (high side pressure, low side pressure, oz's of refrigerant, etc). I have a late 82 car with the early 944 style AC. The 944 FSM seems to only show the late 944HVAC system and the 924 manual shows the early 924 system. I think I'm missing something here. Any tips?
Thanks,
Kevin
v8carreragts
PostPosted: Mon Jun 10, 2013 10:41 pm    Post subject: Reply with quote
You're A/C is the same as the early 944. My 924 manual also has the late system in it but outside of the installation instructions (It was service installable into the 924) it is the same as the early 944. So you can use the pressures and volume of refrigerant from the early 944.
2015 AUDI Q7
2013 Chevy Cruze
