028121405A (924 expansion tank) NLA
PostPosted: Fri Aug 31, 2012 4:02 pm    Post subject: 028121405A (924 expansion tank) NLA Reply with quote
My coolant expansion tank seems to have sprung a leak in the dimple, which seems like a common failure mode.
It seems the part is now NLA.
So, a search shows there's a Scirocco tank that's a suitable retrofit for the 931 tank. Not having one, and knowing the 924 and 931 tanks are different, will the Scirocco tank fit the 924? Or any other tanks?
I hear lots of people do the 944 tank conversion. What does that buy me other than a way forward? I take it that's an option for the 924? Seems most often it's in the context of 931's by the looks of it.
Any suggestions on how to plug the leak in the dimple 'till I get a replacement sorted out?
I saw a suggestion elsewhere to get a 944 tank from rennbay, but I couldn't find one on the site. Any tips on how to do so?
78 924 NA
5-lug
Muz924
PostPosted: Fri Aug 31, 2012 8:20 pm    Post subject: Reply with quote
I thought pelican parts still had them!!
I need a new tank as well as mine is stuffed I would also like to know what our options are.
1978 924 RoW 5-Speed (Current Project)
1980 924 RoW 5-Speed (Donor Car)
1985 Alfa Romeo Alfetta GTV 2.0 (Previous Project Car)
MikeJinCO
PostPosted: Fri Aug 31, 2012 10:51 pm    Post subject: Reply with quote
I got a 944 tank a while back and then found that it doesn't fit if the stock NA airbox and the ignition box are in their standard locations. I'll retry it again today with the idea of moving the ignition and report back.
Mike
'67 MG Midget Dp
Kens_74_911s
PostPosted: Fri Aug 31, 2012 11:28 pm    Post subject: tank Reply with quote
PM Sent have one off a 82 924...
Ken
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars
musicalannette
PostPosted: Sat Sep 01, 2012 7:24 pm    Post subject: Reply with quote
A good, high pressure capable slow set epoxy is probably best.
http://www.maplin.co.uk/plastic-weld-46010
This is is high street available one in the uk.
hope this helps.(sorry its black)
I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737.....
Harm
PostPosted: Sun Sep 30, 2012 5:27 am    Post subject: Re: 028121405A (924 expansion tank) NLA Reply with quote
Ausgleichsbehälter 924 1976 - 1985 , 2 Liter. 109,- €
> http://www.werk924.com <
PostPosted: Wed Oct 03, 2012 1:34 pm    Post subject: Reply with quote
Wow! You always seem to have a knack for finding things.
I've got a used one on now that seems to be doing the trick. I'm going to see about an alternative for the long term.
78 924 NA
5-lug
924-obama
PostPosted: Tue Oct 23, 2012 11:53 pm    Post subject: Reply with quote
sorry guys if it looks like a huge depot. there is one new item left, only. very limited parts
/thomas
PostPosted: Wed Oct 24, 2012 12:32 am    Post subject: Reply with quote
Well the used one I obtained leaks too.
I'll take it!
78 924 NA
5-lug
BionicBalls
PostPosted: Wed Oct 24, 2012 12:46 am    Post subject: Reply with quote
You can use a 944 tank on a 924 NA, but you wont be able to open the airbox to change the filter w/o removing it. Ask me how I know.
1980 924 NA
1982 931
PostPosted: Wed Oct 24, 2012 2:08 am    Post subject: Reply with quote
If its leaking at the dimple, fill the dimple with JB Weld or JB Quick and try again.
PostPosted: Wed Oct 24, 2012 2:50 am    Post subject: Reply with quote
In my experience, fixes like that don't last long term. My replacement has a slow enough leak so that it is manageable for the time being.
I was thinking of other ways to make a more permanent repair, but I'd rather replace with a new one if it's an option.
78 924 NA
5-lug
ninpo4me
PostPosted: Sat Aug 10, 2013 8:58 am    Post subject: bump Reply with quote
I am looking for a new or NOS expansion tank... anybody have a lead on one?
Love me some toofa'
PostPosted: Mon Aug 12, 2013 2:51 am    Post subject: Reply with quote
I've got two that leak at the dimple. . .
78 924 NA
5-lug
