help - terrible noise from motor
B
PostPosted: Thu Jul 04, 2013 10:33 am    Post subject: help - terrible noise from motor Reply with quote
Hey everyone
After hooking up my new walbro fuel pump, I went to start the car up to test it and look for leaks - thankfully it worked and so far no leaks - the car was not the most enthusiastic to get started - especially because it had sat for a while without starting.
When it started it let out a strange crunchy sound once or twice and then a high pitched squeal - the squeal I recognized as a loose alternator belt the crunch not so much. It was muffled behind the squeal and only happened once or twice.
I let it alone until the next day, a little more energetic little to no squeal but a little more crunch. I checked the belt and tightened things up and tried again.
Now no squeal but holy crap that crunchy loud rocks in a tin can sound will not go away.
I don't know how else to describe it besides loud motorized marbles or rocks in a tin can sound.
Now that the long story is over - It sounds like it could be an alternator bearing but I am not sure
Is there anyone else out there that has encountered something like this? any thoughts on what it could be? I am kinda nervous to try to start it again in case it may be something worse.
1979 924 n/a
BAE turbo
5-speed snailshell
B
PostPosted: Thu Jul 04, 2013 10:35 am    Post subject: Reply with quote
I also thought about trying to start it with the alternator belt off - I realize the water pump would also be disconnected, but I thought I might be able to for a second or 2 just to see if the sound is there ...
1979 924 n/a
BAE turbo
5-speed snailshell
Kevin D
PostPosted: Thu Jul 04, 2013 10:41 am    Post subject: Reply with quote
If you loosen the belt tension and spin the alt pulley by hand, how does it feel? If it is the alternator, it should be pretty obvious when you try and turn it by hand.
'88 924S 3L 6sp RedRat
'92 Duc 900ss
'02 Duc 998 Carbon
'72 RD 350
B
PostPosted: Thu Jul 04, 2013 12:26 pm    Post subject: Reply with quote
it spins - but not very well appears to be a bit of a drag to it I had a spare that was no good and it spins freely - much better than the one on the car now
neither has noise
thanks
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Thu Jul 04, 2013 2:42 pm    Post subject: Reply with quote
perhaps the timing belt tensioner?
Harm
PostPosted: Thu Jul 04, 2013 3:21 pm    Post subject: Re: help - terrible noise from motor Reply with quote
Checked the waterpump for play at its wheel?
When its axle wears out, the rotor inside causes to hit the block and will sound horrid…
It can also stop the belt: loud high pitched squeal.
Easy check:
Remove the belt and wiggling the pulley by hand feeling for any play…
When worn it will probably loose coolant around that axle.
HTH
PostPosted: Thu Jul 04, 2013 3:44 pm    Post subject: Reply with quote
+1 on the tensioner.
B
PostPosted: Fri Jul 05, 2013 1:18 am    Post subject: Reply with quote
the water pump seems ok no wiggle that I can see or feel - on to the tensioner next
thanks everyone
1979 924 n/a
BAE turbo
5-speed snailshell
B
PostPosted: Fri Jul 05, 2013 4:28 am    Post subject: Reply with quote
the tensioner (which I forgot is relatively new 1-2 years) seemed fine - did not rotate too freely and made not noise when it was rotating
I am going to look at the turbo next to see if something got in there - I have no idea what
otherwise I am completely lost - I was fairly certain it was going to be belt drive related -
could it still be the alternator?
I am hoping it is not an internal part -
1979 924 n/a
BAE turbo
5-speed snailshell
B
PostPosted: Fri Jul 05, 2013 4:55 am    Post subject: Reply with quote
I think this is a similar sound
http://www.youtube.com/watch?v=zl-AGOplM-8
(hopefully this link works) maybe this type of sound and it increases with engine speed
I may try to start the car without the water pump/alt. belt hooked up to see if it makes any noise - hopefully that will not be bad for a few seconds
any thoughts?
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Fri Jul 05, 2013 5:12 am    Post subject: Reply with quote
Could just be something stuck and rubbing on a belt or pulley.
The timing belt tensioner should spin freely and without noise. Also new parts doesn't always mean they are good.
B
PostPosted: Fri Jul 05, 2013 5:34 am    Post subject: Reply with quote
Thanks Stefan
I was not sure about the tensioner or the alternator - neither spin very freely - a few rotations max then slow and stop
I found an old tensioner that I took off and it spins great but it does have a bit of a grinding sound to it - but the difference between the two as far as spinning is night and day
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Fri Jul 05, 2013 6:02 am    Post subject: Reply with quote
Yep, both should spin pretty well if you give em a good fling. If they don't? That's not great. Luckily the alternators and tensioners aren't too expensive or hard to find, except maybe 4th of July weekend
B
PostPosted: Fri Jul 05, 2013 10:37 am    Post subject: Reply with quote
Thanks Stefan
I think I will give a couple of places a try tomorrow. The alternator was not a stock type it is a summit 100amp - so I will see what they have for that and I think I may have a line on a tensioner as well - hopefully that will take care of it
thanks again
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
B
PostPosted: Sat Jul 06, 2013 3:40 am    Post subject: Reply with quote
ok so the alternator tested ok and did not make any noise at least not at auto zone
the noise was not there when I took the belt off of the alternator, and waterpump - so I did not here anything for the minute or two that it ran - so I might assume the tensioner is ok
After I tested to see if the tensioner was making the noise - I reconnected the other belt and the noise returned instantly
Now I am really out of ideas
could it be
the water pump - it is really loud though and I do not see any signs of leaking
turbocharger I do not know why it would be - but I suppose it could be
something else engine related?
any other ideas or suggestions would be greatly welcome and appreciated
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
