Head bolts NLA?
xanderdeg
PostPosted: Mon Jun 24, 2013 7:01 am    Post subject: Head bolts NLA? Reply with quote
Ordering parts for my head gasket change, I've read right here on the board that head bolts are NLA..
Yet I found these:
http://www.autopartsway.ca/PartDetails.cfm?W0133-1643201/FEB/Porsche/1978/924/Base/2.0L_L4/allB/Engine/Cylinder_Block_Components/Engine_Cylinder_Head_Bolt/pagenum1/tabS
Seems either what I read was wrong or the bolts on this website aren't actually what i'm looking for...
nickthompson
PostPosted: Mon Jun 24, 2013 8:28 am    Post subject: Reply with quote
The head are basicly the same as audi fives. Autohausaz sells them but they require tripple square bits.
xanderdeg
PostPosted: Tue Jun 25, 2013 5:20 am    Post subject: Reply with quote
Thanks, but that doesn't quite answer my question: Will the ones on the site I linked to work?
nickthompson
PostPosted: Tue Jun 25, 2013 9:20 am    Post subject: Reply with quote
Those are exactly like the ones autohausaz sales and they are currently on my car. Go the your local auto parts store and get some tripple square bits.
PostPosted: Fri Jun 28, 2013 12:49 am    Post subject: Reply with quote
Or you can get a complete set of the OEM bolts from me for $34.
http://garage.ideola.com/prod-EngineRebuildKits.html#head
Not sure where you read that they're NLA, but that is not accurate.
xanderdeg
PostPosted: Fri Jun 28, 2013 5:03 pm    Post subject: Reply with quote
You said so yourself right here:
http://www.924board.org/viewtopic.php?p=282993&sid=dae7e475ef9d7acd3df79ed240d8d01c
Head bolts are generally NLA unless you buy used. I have three sets of used head bolts if you're interested; however, they are designed as stretch bolts and not recommended for re-use. The other options are the ARP head studs or Raceware. Not sure who's carrying Raceware these days, but the ARPs are less expensive and easier to install due to the hex head.
{EDIT}
Min, thanks for the plug
PostPosted: Fri Jun 28, 2013 9:05 pm    Post subject: Reply with quote
Yeah, that was back in 2010. I didn't have access to the wholesaler I am now using for most of the OEM replacement parts, nor did I have direct access to order stuff from Germany.
I can now get the Bilstein OEM replacement head bolts, so no worries.
CorsePerVita
PostPosted: Tue Jul 02, 2013 6:10 am    Post subject: Reply with quote
Totally worth it for the ARP head bolts.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
