Wiring issus..
ThomasJoseph315
Guest
PostPosted: Fri Jul 05, 2013 3:34 am    Post subject: Wiring issus.. Reply with quote
So the other day when I cleaned out my WUR one of the wires broke off and the car is starting like crap ever since. So,.. if someone would be so kind as to take a pic of the WUR, probe the wires and point out which is POS and which is NEG that would be just super
Thank you a head of time!
PostPosted: Fri Jul 05, 2013 5:09 am    Post subject: Reply with quote
Brown is always ground. If that helps.
PostPosted: Fri Jul 05, 2013 7:20 am    Post subject: Reply with quote
Does not matter. Key switched +12v on one, ground on the other.
ThomasJoseph315
Guest
PostPosted: Fri Jul 05, 2013 3:52 pm    Post subject: Reply with quote
That's what I thought. But yes good to know brown is ground too,.. will double check this.
Weird thing. before I rewired that thing I had to hold the peddle to the floor to get it started. Force of habit later I realize, holding the peddle to the floor is flooding the engine, lol.
scm924s
PostPosted: Fri Jul 05, 2013 4:10 pm    Post subject: Reply with quote
Holding the pedal down won't flood the engine, in fact it is the Porsche approved way to start the car with a hot engine on the early cars, this is stated in the handbook.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
ThomasJoseph315
Guest
PostPosted: Sat Jul 06, 2013 1:40 am    Post subject: Reply with quote
Was this before they installed WUR and/or using carbs?
nickthompson
PostPosted: Sat Jul 06, 2013 1:50 am    Post subject: Reply with quote
924s never came with carbs.
