Patrick
Joined: 05 Dec 2007 Posts: 278 Location: Manila, PHILIPPINES
Posted: Thu Jul 18, 2013 11:38 pm Post subject: Tierod assembly : Stop Rings concern. Need advice asap |
Hi guys!
I took off the tie rod assembly (from the steering knuckle end till the rack and pinion end) to do something with it, and finally put it back on only to discover that i forgot to slide in the Stop Rings on both tie rod assemblies.
I need to drive to some place nearby real soon (only about 3 miles) , and upon getting there will do some stuff with my car, to include putting the Stop Ring back on. Is that ok (to drive the 3 miles i mean) ? Is there any possible damage, even minor, that can come from driving the 3 miles? The 3 miles i will drive can be taken safely at speeds as low as 30mph if need be. Thanks!
patrick _________________ 1979 924 U.S. version
Single sidedraft Weber 40 |
Posted: Fri Jul 19, 2013 1:34 pm Post subject: |
Stop rings are only to keep the pinion from crashing on the end of the teeth in the rack, which only occurs at full lock.
No danger, drive away. . .just don't repeatedly bang the steering to the ends of its extremes. _________________ Toofah King Bad
Patrick
Posted: Fri Jul 19, 2013 3:31 pm Post subject: |
GREAT! Thanks so much! _________________ 1979 924 U.S. version
