No vaccum produced...?
PostPosted: Sun Aug 11, 2013 6:16 pm    Post subject: No vaccum produced...? Reply with quote
Helllo all,
after swapping an1982 engine into my 1977 924 NA i discovered that there is no vaccum on the line to the ignition distributor.So, the ignition is not able to catch up with rpm`s.
To test it i pulled the hose and put my finger onto the hole, and feld nothing?
What can cause this?
Ideas?
PostPosted: Mon Aug 12, 2013 12:52 am    Post subject: Reply with quote
If it is hooked up to throttle plate vacuum it shouldn't be much unless the engine is revving. Do you have a diagram to confirm everything is hooked up right?
PostPosted: Thu Aug 15, 2013 3:43 am    Post subject: Reply with quote
problem solved,
the vakuum advance inside the Ignition distributor was stucked.The car set for a couple of years.After loosen it and putting some oil on it everything is just fine.
