Exploding brake rotors
daniel
PostPosted: Tue Sep 17, 2013 5:52 pm    Post subject: Exploding brake rotors Reply with quote
Hi All
I have had a little trouble with brake rotors and wheel bearings. Heres the story:
The race weekend before last during the last race I started to notice a vibration in the drivers front wheel, over the course of 1 lap the vibration became worse to the point that I lost control and the car came to rest off the track. When I had a close look, the hub part of the front rotor had been smashed to pieces along with the inner and outer wheel bearings.
The bearings and rotors were about 5 race weekends old and the passengers rotor and bearings were fine.
So I replaced both rotors and all front wheel bearings and entered the next meeting.
During the last race of the next meeting the same vibration returned, so I immediatly pulled over. Upon dissasembling the drivers side wheel assembly, this is what I found:
So now I suspect some issue with the stub axle, perhaps a micro crack that grows with heat and causes a vibration. Regardless the stub axle is now damaged and requires replacement.
My question is this: Have any of you with race cars that have used 4 lug rotors experienced anything like this? Or does anyone have any theories as to what is happening here?
I will say this though, please dont suggest that I should upgrade brakes,that is not possible due to my class rules.
Thanks
Daniel
1989 944 Cabriolet
PostPosted: Tue Sep 17, 2013 8:17 pm    Post subject: Reply with quote
This looks mad..I have done both many many track days and endurance racing with the stock setup (although nice pads, fluid and lines). I have never seen anything like it.
Although I had a bad bearing which self destruct within a trackday or two. Got a new one that time from the seller, SKF, so nice quality. It have worked since then.
Do you tighten the bearing according to the manual?
daniel
PostPosted: Tue Sep 17, 2013 8:51 pm    Post subject: Reply with quote
Hi cedric, i dont know what the manual says about tightening the bearings. I thighten them while the wheel is spinning until it stops. Then i back it off a bit but not too much.as to cause pad knock off.
1989 944 Cabriolet
PostPosted: Wed Sep 18, 2013 4:04 pm    Post subject: Reply with quote
I had an issue with my car eating front wheel bearings which I concluded was due to a bent spindle. I didn't race the car though.
My 5-lug upgrade fixed that.
Too bad a 5-lug conversion isn't allowed for you, even though they were available that way from the factory.
78 924 NA
5-lug
masterslamma
PostPosted: Fri Sep 20, 2013 5:58 am    Post subject: Reply with quote
my brakes glow highly red after driving threw the alps. the had about 8-900 degrees is guess, but thats no problem at all . I run ate powerdiscs, ferodo pads and ate blue racing fluid.
that is definitely not normal
My other car is a Porsche,
but today i am in a hurry!
