Front suspention...
ThomasJoseph315
Guest
PostPosted: Tue Jun 25, 2013 12:48 pm    Post subject: Front suspention... Reply with quote
I got these types of struts, springs and mounts,.. anyone know a part number for all these? Preferably Monroe shocks or perhaps something also in a performance. Not sure what I wanna use just yet.
Power Tryp
PostPosted: Wed Jun 26, 2013 1:18 am    Post subject: Reply with quote
Boy, you've got a ton of options when it comes to suspension on these cars thankfully.
For Part #s Porsche gives access to their original PET cataloging. http://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
In order to help you decide what kind of suspension set up you want we'll need to know what you're looking for in the car. Stock handling? Street car with track day ability or full on track suspension.
Once we know that we can start offering suggestions. Your's is the early model car right?
Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic.
ThomasJoseph315
Guest
PostPosted: Wed Jun 26, 2013 1:37 pm    Post subject: Reply with quote
Hey,..
Yea it's an early 924. Dumb question,.. do these shocks come apart? like you slide them out of the lower part? I am finding a lot of these tube looking ones.
Also,.. If anyone knows price and availability of springs and mounts just encase.
Power Tryp
PostPosted: Wed Jun 26, 2013 3:47 pm    Post subject: Reply with quote
You can see here the strut tube pulled apart awaiting a coil over kit to be installed. http://www.paragon-products.com/kb_results.asp?ID=16
And here you can see the strut completely disassembled. http://www.924board.org/viewtopic.php?t=24501
Upper strut mounts can be bought here. http://www.paragon-products.com/924-Suspension-s/382.htm and Dan sells strut inserts and all the bushings necessary to refurbish your suspension at his site http://garage.ideola.com/prod-SuspensionUpgrades.html
Remember that the suspension in your car (and in all cars) is designed as a package and just changing one thing may give you an undesirable result. So if you can, plan to build a complete setup.
Melanie - 1980 931
ThomasJoseph315
Guest
PostPosted: Mon Sep 02, 2013 12:19 pm    Post subject: Reply with quote
I seen a thread on here about how to change the front shocks/struts without using a spring compressor, that still around. I am trying to search for it now, but if someone finds it before be leave some breadcrumbs pls.
SlayerSST
PostPosted: Mon Sep 02, 2013 12:46 pm    Post subject: Reply with quote
Have fun dude.
http://www.924board.org/viewtopic.php?t=28571&highlight=
http://www.924board.org/viewtopic.php?t=24479
ThomasJoseph315
Guest
PostPosted: Mon Sep 02, 2013 4:46 pm    Post subject: Reply with quote
Just pulled out a set of 4 Gabriel strut/shocks... Who in the right mind would use those on a Porsche? They where all completely blown out!
PostPosted: Tue Sep 03, 2013 8:51 am    Post subject: Reply with quote
You should try using the "Search" feature sometime. . .you aren't the first to wonder about suspension options.
Power Tryp
PostPosted: Tue Sep 03, 2013 1:05 pm    Post subject: Reply with quote
or even better googles advanced search feature http://www.google.com/advanced_search
It's what I use to find info that I'm looking for. It's kept my post count down.
Melanie - 1980 931
Power Tryp
Twice.
Melanie - 1980 931
Slam
PostPosted: Tue Sep 03, 2013 3:01 pm    Post subject: Reply with quote
http://www.924board.org/viewtopic.php?t=33966&highlight=
Hope that link works.
ThomasJoseph315
Guest
PostPosted: Tue Sep 03, 2013 3:12 pm    Post subject: Reply with quote
I ended up just going and renting a set of spring compressors, it was no biggie really.
Thanks for the links tho! The New Strut tubes and rear shocks are in and it drives like a dream! I took it up to 110mph tonight and she floats like a butterfly I even made a Corvette my bitch on the local highway,.. it was a lot of fun
