Pelican or Paragon Front shift bushings?
Patrick
PostPosted: Sun Sep 01, 2013 12:17 am    Post subject: Pelican or Paragon Front shift bushings? Reply with quote
Hi All!
I have the 1979 Snailshell car and plan on replacing my Front Shift lever bushings part # 999-924-002-40 (4 pcs). I checked out Pelican and Paragon.
I then looked at the product picture of each, and Pelican showed what is supposed to be a genuine porsche part (together with the above part number), where the bushing has a slit along its entire length.
The bushing from Paragon ( product code # 944-424-2301) looked different and had what looked like little notches at one end. Its applicability says that it fits 924 NA 1977-1982 and some early and later NA and Turbo 944`s.
So which would be the better choice in terms of performance, quality and ease of fitting? Thank You,
patrick
1979 924 U.S. version
Single sidedraft Weber 40
PostPosted: Sun Sep 01, 2013 12:30 am    Post subject: Reply with quote
THE ONE FROM PARAGON is not correct.
PostPosted: Sun Sep 01, 2013 12:31 am    Post subject: Reply with quote
Patrick
PostPosted: Sun Sep 01, 2013 12:17 pm    Post subject: Reply with quote
That was a simple enough answer. Thank You!
