FFNPMcD
Joined: 15 Aug 2013 Posts: 19 Location: Richmond, Va.
Posted: Thu Sep 19, 2013 4:02 am Post subject: Coolant system normal? |
I recently decided it was time to drain the coolant system to put fresh new coolant in. (not sure when previous owner did it last)
With the coolant being drained I figured it would be a good time to replace the thermostat and aux fan switch. (replaced them to a lower activating temperature)
Now the car never reaches temperatures above 1/2 on gauge while sitting at lights and is rarely above a quarter when driving on highway.
I notice my fans cut on just below 1/2.
After running the vehicle for a while I notice:
1. The top radiator hose and engine block get hot to the touch.
2. The hose from water pump to bottom or radiator remains significantly cooler than the above mentioned parts.
I want to assume the system is functioning properly (with fans on radiator activating) but i'm not really sure I understand the direction the coolant is supposed to flow and worried about the hose temperature differences..
is this normal?
Thanks,
Neill _________________ 1987 924s |
edredas
Posted: Thu Sep 19, 2013 4:39 am Post subject: |
The coolant enters the block at the thermostat and exits through the top hose. So everything you are describing is normal. _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
FFNPMcD
Posted: Thu Sep 19, 2013 4:41 am Post subject: |
Excellent! Thanks for the quick response. _________________ 1987 924s |
