replaced intake manifold gaskets now no start!!!!help!!
ggrecian
PostPosted: Sun Oct 20, 2013 10:41 am    Post subject: replaced intake manifold gaskets now no start!!!!help!! Reply with quote
I have a 1987 porsche 924s..i had an intake leak at an intake manifold gasket but it ran pretty nice considering the easily heard intake leak.i drove the 924 for 20 thousand some odd miles with a little mis. So i replace the intake manifold gaskets and now it cranks but will not start..i replaced the distributer cap.rotor button.plug wires plugs.ignition coil.fuel injectors.i am tired of replacing things and need to get it to start again.need to find the root.have spark.have fuel to the fuel rail.help!!! How do I test the air flow sensor.will not start with starting fluid.so i think i dont have any air?help?
porschelover
larchie
PostPosted: Sun Oct 20, 2013 2:34 pm    Post subject: Reply with quote
If all vacuum lines are in place and no serious vacuum leak from the manifold (i.e., something like cylinder compression nearly nil), it sounds like a timing issue: e.g., re-check distributor proper rotation, wires to the cap proper order, finding TDC for #1 spark so forth. My guess is that the issue is most likely the way stuff was put back together -- something not properly connected..
Slam
PostPosted: Mon Oct 21, 2013 1:23 pm    Post subject: Reply with quote
924S, right? Are you sure you plugged in your AFM, your TPS, DME sensor? Also try swapping the plugs for the speed and reference sensors. They may be backwards. You're probably not in much trouble.
HTH.
ggrecian
PostPosted: Mon Oct 21, 2013 7:47 pm    Post subject: Reply with quote
Thank u guys sooo much.Not sure what the AFM TPS and DME sensors are or where they are located.i made a conscious effort to plug everything back in.any help with where they are located.also at one point i did have the reference and speed sensors swapped----no spark.got them back in proper plug.have spark now..did i do damage by accidently swapping the two and trying to start it many times?ordered a dme relay.should b here soon
porschelover
ggrecian
PostPosted: Mon Oct 21, 2013 8:14 pm    Post subject: Reply with quote
Ok i got u (AFM) air flow meter.(tps) throttle position sensor.air flow meter definately plugged in.not sure where the throttle position sensor is located.also if and when purchasing a reference and a speed sensor.are they the same item? just buy two and put in corresponding plug?cant find speed sensor to purchase
porschelover
Slam
PostPosted: Tue Oct 22, 2013 1:01 pm    Post subject: Reply with quote
Sorry, I should have gone into more detail. Anyway, the two connectors in the bracket at the back of the intake manifold are the plugs for speed and reference sensors. DG and BG I think they're marked. Check the colored tape on them (if it's still there). It's easy to mix them up. The sensors themselves live at the back of the engine on the bellhousing right beside the window for the TDC mak on the flywheel. Much has been written about these little bastards, so I won't reiterate. But if you had your manifold off to do the gaskets you may have disturbed them. BTW, those intake gaskets can be changed without pulling the manifold...
TPS lives right under the throttle body, although the car will run fine with it disconnected. Heck, in some cases run better!
PostPosted: Wed Oct 23, 2013 1:07 am    Post subject: Reply with quote
Aftermarket speed/ref sensor is Facet 12141710668, FWIW. I can sell you a pair for $125 shipped.
