Help need a suggestion on a part locator
creeves84
PostPosted: Sat Dec 21, 2013 11:35 am    Post subject: Help need a suggestion on a part locator Reply with quote
I have a 81 standard 924 that after a issue with higher RPM fuel cut out or lean issue as tested on a dyno the shop has determined I need a new control pressure regulator but I can't find one through the normal sources.
Does anyone know of a interchangeable part from another car-or a source that sells a rebuilt one?
PostPosted: Sat Dec 21, 2013 12:05 pm    Post subject: Reply with quote
Run-on sentences are hard to follow! What exactly is the shop recommending?
Ok, let's start from the beginning, what is the problem?
Slam
PostPosted: Sat Dec 21, 2013 12:13 pm    Post subject: Reply with quote
WUR toast, is what I got out of that. Can be cleaned if need be. Try searching for a warm-up regulator.
Here: http://www.specialtauto.com/warm-up-regulators.html
Dave, why are you here when there's a head to be pulled? And I mean that politely, of course...
creeves84
PostPosted: Sat Dec 21, 2013 12:57 pm    Post subject: Reply with quote
Wow- tough crowd
I will look for advice elsewhere.
creeves84
PostPosted: Sat Dec 21, 2013 12:58 pm    Post subject: Reply with quote
Thanks for your help!
9xx
PostPosted: Sat Dec 21, 2013 6:42 pm    Post subject: Reply with quote
Look also from Ebay. Search for Porsche 924 warm up regulator. And notice that n/a and turbo warm up regulators are slightly different. It is perhaps better option to buy a rebuilt one because used ones tend to fail anyway at some point. Tomorrow or in 2015, who knows.
It is sometimes a tough crowd to please here on 924board but you should just stick around and grow thicker skin. The best information can be found here. Other boards like Rennlist.... a lot of 924 hate there, just bollocks.
Mikko
maybeoneday
PostPosted: Sat Dec 21, 2013 9:33 pm    Post subject: Reply with quote
This is just an observation, you would have to check it out, but when I was looking around a VW golf the other week to see if there were any parts I could scavenge, I thought that the WUR looked very similar. I do know however that the golf had 4 slightly different WUR's and I dont know if they are interchangeable with each other, if any or all are interchangeable with the 924, or if the 924 has slightly different WUR's depending on build year. In the short time I have had my 924 I have gotten a few bits from a golf that is sitting at a friends wrecking yard. I was surprised to see how many bits were similar. The interior light and quite a few trim bits I took, but considered a few CIS bits as many looked similar.
Just thought it may be worth looking into further. You could try using WUR in the sites search function. Sometimes this helps. If I cant find it by searching then I usually ask on the board. The information the guys here have is first class. I have worked on other Porsche models before and used other boards when doing it, and from my experience this board is probably the best information around about any one model.
PostPosted: Sun Dec 22, 2013 1:02 am    Post subject: Reply with quote
It's already off the block, and I'm in the process of trying to get one last bent valve removed. I can't 'squish' the springs enough to get the retainers out. I'm using a magnet, and am sooooo close. Not sure the head is salvageable, the valves hit the edge of each combustion chamber and there's damage. grrrrr.
kcoyle
PostPosted: Sun Dec 22, 2013 10:37 am    Post subject: Re: Help need a suggestion on a part locator Reply with quote
creeves84 wrote:
I have a 81 standard 924. After a issue with higher RPM fuel cut out or lean issue as tested on a dyno the shop has determined I need a new control pressure regulator. I can't find one through the normal sources. Does anyone know of a interchangeable part from another car-or a source that sells a rebuilt one?
Is the shop familiar with CIS systems and were they able to really test the fuel system? You could save some dough by getting a CIS tester and a haynes manual to get some baseline readings.
http://www.924board.org/viewtopic.php?p=350517&sid=3e2c2b277d56b560416417a1628016b3
creeves84
PostPosted: Sun Dec 22, 2013 10:24 pm    Post subject: Reply with quote
Yes the shop is quite familiar with the CIS system. The shop specializes in Porsche and tech worked on them when the CIS launched. The diagnoses came after the shop ran the car on the dyno with gauges connected. The system will go extremely lean at about 3500 rpm. It idles fine, driving under 3500 rpm it performs well, just stumbles above a certain RPM.
The prior owner didn't store the car properly and stored it for about 6 years outside without treating the gas. I did the things I could- replaced the pumps; changed the injectors; had the distributor rebuilt, ect. The fuel was just terrible prior to the draining of the tank. The system is almost all new and hopefully after this is replaced nothing else shows its ugly head.
