walterv
Posted: Wed Dec 25, 2013 3:02 pm Post subject: 1980 924 turbo transmission problem |
Hi All and a merry xmas to all.
So I have this problem ,when I shift from 1st to second gear, I get a grinding noise.
I saw this, copy and paste, from an ad from someone selling a 1980 924 turbo:
-Transmission has second gear synchro issue. It’s a common issues for these Z-pattern 5 speed transmissions to have an issue with the second gear synchronizer, in order to shift to second from first, you must pause for a second or 2 for the synchro to catch up, otherwise it will grind going into gear.
What needs to be done to fix this? I too have the same problem.
Thanks
walter _________________ I am restoring a 1980 924 Turbo, my wife had one when we were married, promised her I would find one for her again one day.  |
Posted: Wed Dec 25, 2013 3:13 pm Post subject: |
Change your transaxle fluid to redline MTL or similar, check your linkage bushes to reduce any slop and finally learn to shift slooowly between 1st/2nd. If it still grinds no matter what then maybe you'll need to rebuild the internals of the transaxle.
Here's me driving my 79 924 which is the less sturdy version of your transaxle (same shift pattern and weak syncros)
http://youtu.be/4XgLYJVX3gQ _________________ Stefan
walterv
Posted: Wed Dec 25, 2013 3:25 pm Post subject: |
OK,
Gonna sound like a real dumb a$$ here, so please excuse that . I assume, when you say "transaxle" you mean what would be equivalent to the rear end gears on an American car. In other words, that piece that is bolted to the transmission?
I am not as dumb as this post sounds, just getting wet behind the ears on foreign cars.
Thanks
Walter _________________ I am restoring a 1980 924 Turbo, my wife had one when we were married, promised her I would find one for her again one day.  |
Posted: Wed Dec 25, 2013 3:30 pm Post subject: |
Yeah, transaxle means the combination of a transmission and the drive axle/differential.
In these cars, it is mounted in the rear and attached to the engine via a torque tube. _________________ Stefan
!tom
Posted: Wed Dec 25, 2013 5:12 pm Post subject: |
If the differential and transmission are contained in a single housing, it's called a transaxle. This is common for front wheel drive cars, but is also found in some other cars (like ours). _________________ 78 924 NA
5-lug |
GeorgeV
Joined: 14 Mar 2010 Posts: 306 Location: Brisbane, Australia
Posted: Thu Dec 26, 2013 6:59 pm Post subject: |
| fiat22turbo wrote: | Change your transaxle fluid to redline MTL or similar, check your linkage bushes to reduce any slop and finally learn to shift slooowly between 1st/2nd. If it still grinds no matter what then maybe you'll need to rebuild the internals of the transaxle.
http://youtu.be/4XgLYJVX3gQ |
I also find that the shifts are a bit smoother when the tranny has warmed up a bit, and making sure I depress the clutch all the way in when changing from 1st to 2nd, from 2nd to 1st, and when going into reverse also helps. _________________ 1981 932 with mods:
http://www.924board.org/viewtopic.php?t=37921 |
walterv
Posted: Fri Dec 27, 2013 12:35 am Post subject: |
Thanks for the explanation and advise
Will let you know how I make out _________________ I am restoring a 1980 924 Turbo, my wife had one when we were married, promised her I would find one for her again one day.  |
Kiwi Classic Driver
Joined: 26 Oct 2013 Posts: 27 Location: Christchurch, New Zealand
Posted: Sat Dec 28, 2013 5:39 pm Post subject: |
Mine is happiest when i take it slowly and double-declutch on the 1st to 2nd shift _________________ 1979 Porsche 924 Turbo
1971 Peugeot 404 pick-up
1970 Peugeot 404 sedan
1930 Durant 614 deluxe coupe
1915 Peugeot type 153A (long-term project) |
