TajMan
Joined: 07 Oct 2004 Posts: 151 Location: Salt Lake City, Utah
Posted: Sat Jan 04, 2014 5:44 pm Post subject: '87 924 S pics after cyl head removal |
Car has around 140K miles on it.
Was always running pretty tops previously, until stored then it had a problem diagnosed as bad headgasket.
Car should be running better and cleaner after headgasket job. Some intake air leaks will be fixed, exhaust was just fixed, ignition components were all just refreshed.
Oily deposits on pistons/head point to running rich/engine inhaling some oil, which is what I'd thought..
bad spot on headgasket, blown open in coolant passage around piston water jacket:
after some piston cleanup, careful scraping with razor blade then wiping with acetone-soaked shop towel:
(one piston done, one partially acetone wiped, 2 somewhat scraped..)
head:
see this valve, the most 'burnt':
So, pics before any head cleanup. .
What say you on the one valve that looks like it suffers more than all the others (exhaust valve cyl #4?)?
Compression was down just a bit on cyl #4 vs the others, but all still close enough proximity engine can survive fine without full head rebuild at this time, IMO.
I think I'll clean up head as best I can and get it all back together with new top-end gasket kit.
Should I do anything, like check for valve leakage with brake parts cleaner sprayed down the ports & pooled up? Is it ever good to replace just one valve with a used valve and no other head rebuild work done?
(unfortunately i'm fixing this car to sell, it won't be my baby I'll keep around) _________________ '87 924 S |
Posted: Sun Jan 05, 2014 1:33 am Post subject: |
Can't be sure from the picture, but that valve may be ok.
If your head gasket set has valve seals, why not pop the valves out, clean and lap them and install the seals? _________________ White 87 924S "Ghost"
TajMan
Posted: Sun Jan 05, 2014 2:03 am Post subject: |
I had seen this:
http://www.youtube.com/watch?v=5GWBrsGTR2s
Maybe I can fab my own tool to compress valve springs for removal? If I wanted to replace valve stem seals I'd need something to do that.
How would you go about 'lapping' by hand with valves removed? 2,000 grit sandpaper after cleaning? _________________ '87 924 S |
edredas
Posted: Sun Jan 05, 2014 10:22 am Post subject: |
| TajMan wrote: | | How would you go about 'lapping' by hand with valves removed? 2,000 grit sandpaper after cleaning? |
There is a compound you use to match the valve against the seat.
While you got the head off and header removed, I would change the oil cooler seals. _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
TajMan
Posted: Mon Jan 06, 2014 7:49 am Post subject: |
I'm so glad you linked a thread on DSM tuners, haha! _________________ '87 924 S |
