Idea for an 931 intercooler kit, while keeping stock look
jaspervanweerd
PostPosted: Tue Nov 26, 2013 7:31 am    Post subject: Idea for an 931 intercooler kit, while keeping stock look Reply with quote
Hi all,
I have purchased a misc intercooler and I am looking for options to mount it. My goal is to make it look as stock as possible. There are plenty of examples where people chop the charge tube to hook up an intercooler, often front mounts. Or modify it to accommodate a liquid/air cooler... All perfect solutions, but I would like something that is esthetically more pleasing and that looks stock .
Of course one can dish out $1500+ to get a TMIC found on the Carrera models. Even though it is basically bolt on, it still requires one to cut a gaping hole in the bonnet and install the appropriate scoop. I think in all, TMIC, scoop and body work will set you back around $ 2000. Again, a perfect solution (heck Porsche found it good enough for the high performance Carrera models:P) but is does affect the stock look of a 931.
I want something that is equally bolt-on with minimal metal work and when popping the bonnet, everything should look like it was before.
In my opinion that leaves only one place for modification, the lower pressure duct:
What if this same section of metal was replaced by a custom pressure duct that, instead of letting air pass through to the charge tube directly, directs it through a front mount intercooler first.
Well I spend a bit more time on this brain fart and made a 3D model of how such a thing would look like. Bear in mind this was made based on looking at pictures of the original duct and late at night . The real one would require a bit more fine tuning of course.
But I hope this give an idea. piping and such can be routed under the fuel dizzy keeping them out of sight. And fed to the front mount under the head lamp (minor metal work). Even though the cold and hot side are connected by a piece of metal to maintain integrity, heat increase I would expect to minimal..
Of course, I can hear you think... All nice and dandy but how are you planning to fabricate this, under the premise it would all work... (FYI, I don't have any metal work experience or own a welder etc...)
Well, due to the powers of 3D printing you can actually print this in stainless steel. A spin-off company from Phillips actually does this in Eindhoven the Netherlands:
http://www.shapeways.com/materials/steel
Material properties, stainless steel with bronze. Looks like it would suffice for this application...
http://www.shapeways.com/rrstatic/material_docs/mds-stainless.pdf
Well I am looking forward to start a nice discussion about this. In the meantime I will be fine tuning the model and making it more accurate.
Hopefully this will result in an affordable and relatively easy way to install an intercooler on our beloved 931s
Jasper[/url]
PostPosted: Tue Nov 26, 2013 8:30 am    Post subject: Reply with quote
Fascinating idea. Looking forward to seeing what you come up with.
PostPosted: Tue Nov 26, 2013 5:27 pm    Post subject: Reply with quote
That looks like a nice idea !
What inner diameter do those pipes have?
I'll take a look under the hood to inspect feasibility.
PostPosted: Tue Nov 26, 2013 7:31 pm    Post subject: Reply with quote
Your two limiting factors is space and keeping the flow as short as possible with limited bends that restrict flow. That's before you have to start moving existing components and cutting things. Good luck.
I used the Carrera GTS with a little 944 turbo as inspiration for my install.
kcoyle
PostPosted: Wed Nov 27, 2013 10:56 am    Post subject: Reply with quote
Great idea, but from what I see there is no room for anything like that. Between the fuel distributor, frame rail, and body itself it's mad tight.
Maybe your piping with a fuel distributor relocation?
I've stared at that part of the car drinking beer and sometimes coffee, and neither have helped with a good IC idea. probably any good ideas actually.
Some crappy pics for reference.
PostPosted: Wed Nov 27, 2013 11:57 am    Post subject: Reply with quote
I think there was a Holbert IC setup in that area. Obviously no squirt bottle.
PostPosted: Wed Nov 27, 2013 5:01 pm    Post subject: Reply with quote
Neat solution, I thought about fabricating a similar, but I cant see how there would be enough space. one tube could go under the CIS, but I cant see both going past there. But try hard, I hope it works...
When you are done with your design send me an .stl and I will print it in 3d (plastic) and do a test assembly
PostPosted: Wed Nov 27, 2013 11:42 pm    Post subject: Reply with quote
My current thoughts on FMIC... I aim to add the 951 IC, starting with stock turbo and CIS.
Ultimately I intend to rework the intake to put the throttle body up front just like the 951, for cleaner airflow path... but for now, I think what I'll do is eliminate the charge tube and pressure duct entirely.
I plan to use a silicone connector hose with a 90 deg aluminum bend to shoot forward to the IC, under the CIS fuel distributor... then back with a straight pipe and bend (approx 135 deg) back into the stock throttle body (with another silicone connector hose section).
This should be relatively easy to make, other than a couple of aluminum welds (but I can do those easily), and also pretty easy to mod out to relocate the throttle body and eliminate the CIS when I'm ready...
No, no pics, sorry...
kcoyle
PostPosted: Sat Nov 30, 2013 7:48 am    Post subject: Reply with quote
Correctamundo. Pic stolen from emoore924.
PostPosted: Sat Nov 30, 2013 8:37 am    Post subject: Reply with quote
No pop up lights either so not looking so stock
PostPosted: Sat Nov 30, 2013 6:02 pm    Post subject: Reply with quote
emoore924's car could have pop-ul lights.
mine does and i use thicker pipes
kcoyle
PostPosted: Sat Nov 30, 2013 11:49 pm    Post subject: Reply with quote
Morghens car for headlight reference. Do you have more room for the IC due to the different front end?
PostPosted: Sun Dec 01, 2013 4:14 am    Post subject: Reply with quote
I had a custom front bumper and it had much more room..but its gone now.
I have the 951 front end(glass fiber) and the 951 bumper offers alot less space so right now the intercooler is mounted 1inch from the radiator and it sits vertically. However the routing inside the engine bay is identical.
PostPosted: Sun Dec 01, 2013 7:08 am    Post subject: Reply with quote
No Pop up lights on that car.
nwns
PostPosted: Thu Mar 20, 2014 6:15 pm    Post subject: Reply with quote
One of dan's top mount chargecoolers is the only bolt on, no cutting, easy remove way. Everything else is a lot of work.
Pete
