fuel pump works sometimes
ddharper2
PostPosted: Sat Mar 15, 2014 5:50 am    Post subject: fuel pump works sometimes Reply with quote
Is it possible to bypass the relay and run a bypass jumper off the key to the fuel pump? I realize that the relay will stop the pump in case of an accident and/or engine quits running. But, will it work,
Thanks Daryl
edredas
PostPosted: Sun Mar 16, 2014 5:07 am    Post subject: Reply with quote
Yes, you can jumper the relay, however it is only recommended for testing purposes and must be removed once the engine is shutdown.
http://www.clarks-garage.com/pdf-manual/fuel-05.pdf
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
