jdub
Posted: Thu Mar 20, 2014 5:08 pm Post subject: ? pressure tests Q, results CIS gauge |
Results:
system pressure seems good at aroun 4.9 bar
COLD pressure (with plug disconnected from WUR and tester valve opened):
SAME as system pressure 4.9 bar when pump is on, then drops to 3 when pump is off
(from there, seems to drop to about 2 bar in 10 min and then stays pretty steady)
Warm- (wur plug connected- but car not heated up of course)
SAME results as cold
Quick Q: So is this totally the WUR / Control Pressure Regulator ?
Update:
Seems like the wires/plug going to the WUR has 9 volts going to one spade
Same with the auxilary air valve plug (ignition on, car not warm)
(i'm the one with the super hard starting and about 5 minutes of rough idling, in 80 degrees temps outside, after sitting a few hrs, no leaking injectors, fuel supply is strong)
Thanks!! _________________ 81 924 non-turbo |
ThomasJoseph315 Guest
Posted: Fri Mar 21, 2014 12:35 am Post subject: |
Check you grounds to the body-engine-ignition-coil-cluster under the dash. I am not sure where the ground for that thermo-switch ends up, I'd have to look at a diagram. But you might have a week ground if it's only 9volts. If you look into this you may get a faster warm up. Sounds like your getting the warm up from the engine it's self which is why it's taking a long time.
Nice to see it's running  |
jdub
Posted: Fri Mar 21, 2014 1:23 am Post subject: ground cluster |
interesting tom,
anyone know where grounds to the thermo time switches end up so ican trace it?
under dash area seems griunded fine after tests.
back to the WUR issue- my COLD pressure test results shiuld be unrelated to a weak ground since the plugs are removed anywyays.?
tgere should still be a lesser Bar when changing from system pressure to open the valve and doing the cold pressure.
? _________________ 81 924 non-turbo |
larchie
Posted: Fri Mar 21, 2014 3:53 am Post subject: |
| jdub wrote: | | Quick Q: So is this totally the WUR / Control Pressure Regulator ? |
Most likely the control pressure is not rising when the electrical terminal to the regulator is re-connected because there isn't sufficient voltage at the regulator plug. You need 11.5 volts and a good ground.
It's possible you might have some internal leakage in the warm-up regulator or the fuel accumulator since during the leak-down tests (after the engine is warm, fuel pump off, etc.) the pressure should hold 2.4 bar for 10 to 15 minutes. I know this isn't what you want to hear, but I don't think you can know anything for sure until you get the voltages and grounds right.
| jdub wrote: | | ... anyone know where grounds to the thermo time switches end up so ican trace it? |
The grounds at issue are (1) the ground near the distributor from the temperature switch and (2) the ground of the body of the thermo switch for the cold start valve. See the wiring diagrams and discussion posted earlier in your previous thread entitled way to test Warm Up Regulator? wur cold start electric test.
Questions:
(1) Did you get about 35 ohms when you measured resistance across the two terminals of the warm-up regulator?
(2) Is the engine hard to start after a warm engine is shut off for 30 minutes? |
jdub
Posted: Fri Mar 21, 2014 6:12 am Post subject: wur resistance |
okay ihave the wur pulled, and remembered the "layers" of little screen filters, and the finer they get, the more clogged they were.
i am now measuring resist across 2 terminals.
10.4 ohms
i jumped the terminals directly from battery, 12v . the resistance then was around 9.4 after a couple min.
ps- the Haynes says like 15. i think ?
i do beleive i was holding 2.4 bar after system pressure test with valve clise, for 20 or more min _________________ 81 924 non-turbo |
jdub
Posted: Fri Mar 21, 2014 6:21 am Post subject: |
ps. The plug for wur is providing 11.4v when key is on, reading both terminals with my dmm, - and +
thanks _________________ 81 924 non-turbo |
jdub
Posted: Fri Mar 21, 2014 7:25 am Post subject: wooo hoooo ! ?? |
car just fired up nice right now- after reinstalling WUR !!! maybe it was the inner finer screens brushed clean ? thanks Tom- or my marvel mystery oil inside the WUR circle disc area (lookin to seal up any possible keak in there at that round seal.
i now have to give it a couple hrs of sittig and see.
thanks for the help - fingers crossed! _________________ 81 924 non-turbo |
larchie
Posted: Fri Mar 21, 2014 7:29 am Post subject: |
These data look good. I guess I'm not understanding exactly how you are testing. Could you explain a little more the following?
| jdub wrote: | | tgere should still be a lesser Bar when changing from system pressure to open the valve and doing the cold pressure. |
I'm not sure what this means and how you are testing. Is it something like this ...
(1) Engine not run for several hours, pressure gauge connected with tap open, leads removed from WUR, engine run at idle, and control pressure is checked to get reading of X.
(2) Engine is warm, leads connected to WUR, pressure gauge connected with tap open, engine runs at idle, and control pressure is checked to get a reading of Y.
(3) Readings of X and Y are about the same.
(4) Engine is switched off and the pressure reading after 10 to 20 minutes is within specification.
or was the last step ...
(4') Engine is switched off, tap is closed on gauge and pressure reading after 10 to 20 drops to within specification.
Additionally, the most important questions are first is my understanding of (3) above correct?
and, again, second, is the car hard to start after a warm engine was shut off for 30 minutes of so? |
larchie
Posted: Fri Mar 21, 2014 7:33 am Post subject: |
| Looks like our posts got just crossed. Looks like the WUR is OK. |
jdub
Posted: Fri Mar 21, 2014 9:50 am Post subject: q pressure testing |
HI
I may have done it wrong from what you were asking above.
It sounds like the pressure testing is to be done with car running?
I did the gauge tests with just the pump running, and like this:
1. system pressure (closed valve on my tester line heading towards WUR, so the pressure regulator isn't involved)
5 bar
2. cold - unplugged WUR, opened the valve on my test line, ran pump,
same bar - about 5
3. same thing with plugged in WUR
About 2.5 bar overall pressure after sitting an hour
THanks! _________________ 81 924 non-turbo |
larchie
Posted: Fri Mar 21, 2014 2:46 pm Post subject: |
I didn't get a clear picture of what the conditions were when you ran these tests, so I'm going to try to put them in my own words:
Test 1 for system pressure: (a) The engine was cold. The electrical connectors from the warm-up regulator and the auxiliary-air device were disconnected. The fuel pump was run and air was bled out of the system at the gauge by opening and closing the valve several times. (b) The gauge valve was closed, and the fuel pump run and you read 5 bar.
{Comment: this is OK.}
Test 2 for cold -control pressure: (a) The engine was cold and the warm-up regulator wasn't hot to touch. The electrical connection to the warm-up regulator remained disconnected. (b) The fuel pump was run and the gauge value was opened so fuel should have been sent to the warm-up regulator. You measured 5 bar.
{Comment: this is not OK. Your cold- control pressure should be about 1.5 bar. By now running the fuel through the warm-up regulator the gauge should have shown a drop from what you measured as system pressure.}
Test 3 for warm control-pressure: (a) The plug to the warm-up regulator was reconnected (so that the regulator will heat up). (b) The fuel pump was run and the pressure remained at 5 bar.
{Comment: this is not OK. The pressure should have slowly risen to about 3.6 bar over a period of two minutes.}
Normally if the pressure does not rise from the cold-control pressure reading to higher warm-control pressure reading, you would check for restrictions in the fuel return line (assuming your supply voltage to the warm-up regulator was 11.5 volts which you said it was). But you should have started from a much lower cold-control pressure. Had you done so and if the return line was clear, the warm-up regulator would definitely be faulty.
But before replacing the warm-up regulator, you need to see if you can clear up the restriction preventing fuel from passing though the warm-up regulator. |
jdub
Posted: Sat Mar 22, 2014 1:59 am Post subject: solved? wur control pressure regulator |
fired right up after sitting all night
must've been the inner screens in the WUR, which i missed the first time ihad pulled it . i only had cleaned the one i could see the first time.
or maybe a sealed up leakage inside the cylinder part if it after i conditioned it. ?
or, a better connection somewhere in the plugs or grounds after messing aroud so much
or all of the above
Anyone need a new set of valve stem seals? $20.hasn't smoked since the a/f lean for emissions
thanks for those who helped! now i can get to some more fun needs on it. _________________ 81 924 non-turbo |
Posted: Sat Mar 22, 2014 2:32 am Post subject: Re: solved? wur control pressure regulator |
| jdub wrote: | fired right up after sitting all night
or all of the above
thanks for those who helped! now i can get to some more fun needs on it. |
Hehehe,.. Your welcome. I would hold on to those stem seals. There really not that hard to change, I'd say even easier then changing that starter you just did. Keep them for now, but keep an eye on your oil level. I was burning about a quart every 2 months. Now after changing them, I haven't noticed any loss at all, but will keep you posted. One thing you will notice, especially if you have a wide band sensor installed. That even though you passed emissions by leaning it out, you could have been burning oil and not gas. You don't get power from oil, so hold on to them for now and keep an eye on the oil. Maybe next month or so check the oil and consider changing them if needed. Also, while your there, you can tune the valves. I loved tuning mine as when I was done it sounded really fresh Doubly so as i actually had a broken spring, lol. |
larchie
Posted: Sat Mar 22, 2014 5:27 am Post subject: |
| jdub wrote: | | ... fired right up after sitting all night |
That's really good news! It looks like you have solved the cold-start problem.
While the know-how of running the pressure tests is fresh in your mind, you might consider re-running them in order to (1) record the pressures as a reference benchmark for when the fuel system on this particular 924 has a problem in the future, and (2) if, hopefully not, the readings aren't within Bosch's specifications, you can check and correct for possible restriction in the fuel return line. |
