ptheskil
Posted: Fri Apr 12, 2013 4:00 am Post subject: How quickly do you/should you change gear? |
I don't mean in a racing situation but in normal driving when you are trying to preserve transmission/synchro life. No special techniques like double declutching but ordinary single declutching with rev matching. I have always changed reasonably slowly allowing time for each of the operations to complete during the change.
I heard an argument recently that you should always shift as quickly as possible so that you provide the maximum force on the synchro cones and allow slip for as little as possible. Whereas I always believed that a steady approach was better since the medium for shear force transfer is the oil film which will transfer the force with little wear if you are using the correct oil.
Would be interested in your opinions. _________________ 1981 931 series2 Euro spec |
Posted: Fri Apr 12, 2013 4:07 am Post subject: |
Bottom line, if you shift too quickly / firmly / forcefully on the G31, you will grind the dog teeth to nubs. So nice easy "pushes" and "pulls" are ideal. All of my street cars now have G31s, and all have been rebuilt (aside from the CGT, which shifts perfectly); in all cases, if you "power shift" from 1st to 2nd, you WILL catch the dog teeth even on a freshly rebuilt gearbox, which over time will ruin them. There's sort of a rhythm to it. In some theoretical universe, there may be some ideal way to shift to preserve the synchros (which I am not qualified to comment on), but in my opinion, it's not the synchros you should care about as much as the dog teeth. Synchros are relatively cheap and still obtainable. Dog teeth, not so much. _________________ erstwhile owner of just about every 924 variant ever made |
MikesCoupeGT
Joined: 18 Oct 2006 Posts: 474 Location: Ontario Canada
Posted: Fri Apr 12, 2013 4:10 am Post subject: |
In regards to how fast you should change gears. I find that if you are deliberate in how you change, there is no point in rushing the gear change. Keep it fluid and smooth and in the end if you are enjoying your car that is what matters.
When I shift I blip the throttle on up and match rev's on down shifts. That is my way of doing it.
regular street driving you don't need to be fast. For track driving you want to speed it up, but it always gets faster with practice.
just my two cents. _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line |
Posted: Fri Apr 12, 2013 4:32 am Post subject: |
Interesting theory on the quick shift, but I don't buy it. On my 931 with snailshell, I treat shifting (especially the 1-2 shift as mentioned by Dan) as a two step process. . .1 to N, then N to 2. I think this keeps my snail happy (along with Redline gear oil).
FWIW, I also am in the habit of rev-matching and double clutching on downshifts, so my snail will probably outlast the car! _________________ Toofah King Bad
Posted: Fri Apr 12, 2013 7:42 am Post subject: |
Here's a quick drive in my 924 with the snailshell:
http://youtu.be/4XgLYJVX3gQ
Just testing the camera (wrong location and wrong recording setting), but it should give you an idea on how slowly a snailshell shifts, especially 1st/2nd. _________________ Stefan
Ponz
Posted: Fri Apr 12, 2013 8:11 am Post subject: |
If I am not in a hurry I skip gears on all my cars without any problems.
Sometimes 1-3-5, 1,2,4. I have been doing it forever and never had a tranny fail. Around town in slow traffic normal shifting.
Porsches owned about 9 in 45 years. Not bad, I think. _________________ 77 1/2 track car
79 931 Euro
87 911 Targa |
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Fri Apr 12, 2013 11:23 am Post subject: |
I find my non-snailshell 5-speed box can usually take faster shifts than I am willing to do, especially once it's warm. But I don't like doing that because it feels I'm forcing the selector. I much prefer that the gearbox "wants" the gear when I change. Which means not too fast - it is technically a selector, after all, and shouldn't need lots of force! (My Lancer was the same, which I had to remind my Dad a few times.)
On downshifts, I sometimes, but always, blip the throttle coming down. I often come down from 4th straight to 2nd. But I've done that in all the cars I've owned.
Wade. _________________ '82 British NA - Which I think I've been very lucky with! |
Posted: Thu May 01, 2014 7:35 am Post subject: |
edit, decided to make it a new thread... _________________ 80 Turbo - Slightly Modified |
Joined: 29 Jul 2001 Posts: 9130 Location: Royal Oak, MI, USA
Posted: Thu May 01, 2014 10:15 pm Post subject: |
Certainly they'll pop out of gear pretty quickly, as you're just unloading things. I'd say, as a rough measure, that around 1 second to go from Neutral to in-gear is a good rough guideline, at least on a non-snail box. Though yes, we do it a bit faster in the racecar, and it can deal.
But on the street, I prefer not to force things. Unless I'm driving a test car; then I've had it down to as little as 200ms. (with data to prove it)
Oh, yeah - it's also possible to go TOO slowly, and then the synchros don't work due to lack of enough pressure to operate, and you end up grinding the gear anyway! LOL But it's pretty obvious to tell when you've done that...
HTH... _________________ Vaughan Scott
pmcaya2
Joined: 24 Nov 2005 Posts: 191 Location: Scio, NY USA
Posted: Sat May 03, 2014 3:52 pm Post subject: |
As Mike said " Keep it fluid and smooth". It's hard to hurt a manual transmission in normal driving.
It's more important when you shift than how fast. I regard my 924 as peaky - wind it up in the lower gear and shift smoothly to the higher gear with enough revs to stay on the power curve for the up gear. In other words, don't bog it down.
Fluid and smooth - the engine shouldn't know you shifted. Likewise if you have to slow down in traffic, down shift to stay on the power curve - again don't bog down the engine. If I could make a rule - shift to please your engine. |
SlayerSST
Posted: Sat May 03, 2014 4:52 pm Post subject: |
| G31/Dogleg = Junk. Remove and take to scrapyard for money. |
Posted: Mon May 05, 2014 2:25 pm Post subject: |
Lolz _________________ Toofah King Bad
Posted: Mon May 05, 2014 3:54 pm Post subject: |
| SlayerSST wrote: | | G31/Dogleg = Junk. Remove and take to scrapyard for money. |
Is this irony I cant understand or the most retarded comment possible? _________________ 1980 924 Turbo
Posted: Mon May 05, 2014 10:53 pm Post subject: |
| Cédric wrote: | | SlayerSST wrote: | | G31/Dogleg = Junk. Remove and take to scrapyard for money. |
Is this irony I cant understand or the most retarded comment possible? |
Probably someone who only thinks a real transmission comes with a name like "rock crusher" or "hydramatic"  _________________ Stefan
pmcaya2
Posted: Wed May 07, 2014 2:50 pm Post subject: |
| Quote: | | Probably someone who only thinks a real transmission comes with a name like "rock crusher" or "hydramatic" |
Are you calling him shiftless? |
