Adjusting the headlight buckets
MikesCoupeGT
PostPosted: Sun Jul 27, 2014 3:55 am    Post subject: Adjusting the headlight buckets Reply with quote
So I have been driving my car around with the flip up headlights. Thing is they are not lined up properly with the engine lid, and I want to move them in so the gaps line up better. Trouble is when I have looked at this there really isn't a way to "slide" the whole assembly one way or the other. Am I missing something. I will post pictures later of how they are lined up and the gaps a bit later.
Any help is much appreciated.
Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Sun Jul 27, 2014 12:18 pm    Post subject: Reply with quote
Is the hood installed correctly?
MikesCoupeGT
PostPosted: Sun Jul 27, 2014 12:51 pm    Post subject: Reply with quote
Yes the hood is installed correctly. I know it is how the headlights were installed, because I just kind of threw them in and didn't look to align them or anything. Pictures will be uploaded tomorrow
Cheers;
MikesCoupeGT
'76 924
'83 944
MikesCoupeGT
PostPosted: Mon Jul 28, 2014 5:14 am    Post subject: Reply with quote
Here are pics from each side. (I hope they work) As you can see there is a large gap going to the center of the car.
[img]<iframe src="https://www.flickr.com/photos/93672870@N05/14573068420/in/photostream/player/" width="640" height="360" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>[/img]
aand the drivers side
<iframe src="https://www.flickr.com/photos/93672870@N05/14757420854/in/photostream/player/" width="640" height="360" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Cheers;
MikesCoupeGT
'76 924
'83 944
PostPosted: Mon Jul 28, 2014 5:29 am    Post subject: Reply with quote
Pics did not work. Are you trying to move them fore and aft, or side to side?
SlayerSST
PostPosted: Mon Jul 28, 2014 6:09 am    Post subject: Reply with quote
https://flic.kr/p/ocLMwm
PostPosted: Mon Jul 28, 2014 6:16 am    Post subject: Reply with quote
Pics need to end in the actual filename of the picture so blahblah DOT jpg or gif, etc. So on your links, when you view them you just need to rightclick on the pic and choose view picture and the resulting address is what you would use in the forum post:
MikesCoupeGT
PostPosted: Mon Jul 28, 2014 7:52 am    Post subject: Reply with quote
Thank you for fixing the pics for me.
I want to move them side to side to have them better positioned as you can see from the pics, they have a terrible gap and I just want to clean it up a touch. Make it look that much better.
Thanks
Cheers;
MikesCoupeGT
'76 924
'83 944
PostPosted: Mon Jul 28, 2014 9:29 am    Post subject: Reply with quote
Side to side adjustment is controlled by shims. The headlight linkage has to be completely removed to address this.
Stand by for pics.
MikesCoupeGT
PostPosted: Mon Jul 28, 2014 10:38 pm    Post subject: Reply with quote
Thanks Rasta.
I will wait to see how this is done. I was hoping it would be a nice simple thing to do, but when the snow flies then I will have the time to shim it up and move them over to have a better gap.
Cheers;
MikesCoupeGT
'76 924
'83 944
jason c
PostPosted: Tue Jul 29, 2014 11:19 am    Post subject: Reply with quote
You'll have to pile a lot of shims in there to move them that much. You may find washers in the tube part of the frame that holds the light where the triangle mounts fit in. You can add/move washers side to side to center the light assembly over.
