Shifter loose
MikesCoupeGT
PostPosted: Thu Sep 04, 2014 11:30 pm    Post subject: Shifter loose Reply with quote
Slowly getting the car to where I really want it. Now the big thing is the Gear shift. It is loose and wobbles around like nobody's business. No matter what gear I am in, there is about an inch of play. I want to tighten this up and make it better. So talking to my dad, who is a local Porsche guru here in Ottawa, he said that there is a bold that holds the gear shift lever in, and if it is not a special bolt this scenario will happen. Is this true? If it is where do I get said bolt. Because once I get the new bolt in, if I still have the problem I will be pulling the gear shift out and making a nice new bushing for it.
Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line
PostPosted: Thu Sep 04, 2014 11:41 pm    Post subject: Reply with quote
There are several posts in the How To section on fixes. On mine the hole thru the shift lever was worn as well as the pin so I drilled it out and put some plastic bushings on it with a new bolt. Problem gone.
Mike
PostPosted: Thu Sep 04, 2014 11:47 pm    Post subject: Reply with quote
You've got the audi gearbox, correct? If so, the shift lever itself is likely worn out.
Read this: http://www.clarks-garage.com/shop-manual/trans-07.htm
I had to repair the shifter in my 951, I cut the worn pin off the lever, drilled that spot for a 10mm threaded hole, tapped it and put a 10mm bolt in place of the pin with a jam nut and loctite to hold it all in place. Later I added a pair of 10mm thrust bearings to help improve the feel.
Like this:
http://944v8.blogspot.com/2013/02/transmission.html
and here's my repair:
http://s148.photobucket.com/user/fiat22turbo/library/Porsche951/Shifter_repair
The thrust bearings are cheap and available from Amazon for about $7/ea.:
http://www.amazon.com/gp/product/B002IG3F60/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Or you can buy the Only944.com shift lever for $50, which is a drop-in and ready to go solution, that includes the thrust bearings and a slightly shorter throw:
only944.com/partscatalog/only/shifter/
If you have the Porsche (snailshell) gearbox then the bushings in the rear "knuckle" are likely gone and need to be replaced. They are 914 shift linkage bushings and quite cheap, not terribly easy to replace, but once done you'll be good to go for quite a while.
MikesCoupeGT
PostPosted: Fri Sep 05, 2014 12:05 am    Post subject: Reply with quote
I will definitely check the how to section.
Fiat22: Unfortunately I have the 4spd box.
Cheers;
MikesCoupeGT
'76 924
'83 944
PostPosted: Fri Sep 05, 2014 12:14 am    Post subject: Reply with quote
Shift lever is the same. You have nearly the same gearbox as the later Audi 5-speed just minus a gear. An Audi 5-speed from another 924 NA would bolt right up (though the extra length for 5th gear might hit the tank). The shift lever arm is different length but the shift lever itself is the same.
Either way, the failure mode and repair are the same for the shift lever no matter what.
MikesCoupeGT
PostPosted: Fri Sep 05, 2014 1:04 am    Post subject: Reply with quote
Good to know. Thanks
Cheers;
MikesCoupeGT
'76 924
'83 944
