kcoyle
Posted: Sat Sep 13, 2014 9:56 pm Post subject: Help reading torque specs |
I understand the +/- thing but in the last line below (Tie rod to steering knuckle) whats going on there? Doesn't compute.
 _________________ 1982 931- Stock with MBC at 8psi
Posted: Sun Sep 14, 2014 2:24 am Post subject: |
Start at 30, check hole for cotter pin. Tighten further to line up hole, but don't exceed 50.
*Above is edumocated guess only! Reliance on the above is reliance on my somewhat spotty edumocation! _________________ Toofah King Bad
Ian89C4
Posted: Sun Sep 14, 2014 2:34 am Post subject: |
I concur with Rasta. Its probably a wide range so that you can line up the castellated nut with the cotter pin hole. It would suck if you hit 30 and the hole was blocked and you couldn't go any further without risk of breaking the bolt.
Cheers _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
kcoyle
Posted: Sun Sep 14, 2014 2:39 am Post subject: |
Sounds good to me. Thanks! _________________ 1982 931- Stock with MBC at 8psi
