brealytrent
Joined: 28 Dec 2008 Posts: 414 Location: Goldsboro, NC
Posted: Mon Sep 08, 2014 10:55 am Post subject: 931 Pic Questions: Where does this go and what goes here?! |
Where does this go?
What goes here (The tube on the bottom of the one intake runner)?
I'm trying to piece the car back together, but I've hit a couple bumps, like these two things. The haynes manual I can't find anything, as well as the parts fiche. _________________ 1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman |
jason c
Posted: Mon Sep 08, 2014 11:29 am Post subject: |
| The 90° boot goes to the turbo POV. The other end to the intake. |
Posted: Mon Sep 08, 2014 12:13 pm Post subject: |
PIA to install, you'll have to take out the air cleaner, probably the CIS; just unbolt it and bend it over, carefully, over the engine. Stuff rag in the turbo. Even with access, this is not a fun job. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
brealytrent
Posted: Mon Sep 08, 2014 1:57 pm Post subject: |
Well, it's good to know where that one line goes. And don't worry, everything is pretty much removed from the car, just set it all back in to get a better idea of how it all goes back together!
Now, what goes on that nipple? _________________ 1977 Porsche 924 - sold
Posted: Mon Sep 08, 2014 2:25 pm Post subject: |
The piece in your hand. Timing belt has to come off, I think. . .tube bolts to the engine via a water pump bolt. _________________ Toofah King Bad
kcoyle
Posted: Fri Sep 12, 2014 9:08 am Post subject: |
| Rasta Monsta wrote: | | The piece in your hand. Timing belt has to come off, I think. . .tube bolts to the engine via a water pump bolt. |
yup, I believe that's a fun one.
 _________________ 1982 931- Stock with MBC at 8psi
Joined: 29 Jul 2001 Posts: 9135 Location: Royal Oak, MI, USA
Posted: Fri Sep 12, 2014 9:22 pm Post subject: |
Yeah, it may even end up being necessary to remove the water pump slightly to wedge it in there. Make sure those boots don't have cracks!!! Very annoying to have to replace after install.
In case it isn't clear, the straight piece of hose is on the intake end, the elbow attaches to the turbo. _________________ Vaughan Scott
Posted: Fri Sep 12, 2014 10:15 pm Post subject: |
Careful with the rubber bits, both of those pieces are NLA, and the upper one to the manifold typically is difficult to remove after 34 years. So, they can get butchered on removal; yours looks good from here though! _________________ '83 944 Track car.
