Is the 931 exhaust turbine housing adjustable?
brealytrent
PostPosted: Tue Sep 16, 2014 2:48 pm    Post subject: Is the 931 exhaust turbine housing adjustable? Reply with quote
Was getting ready to finally put the new turbo I had Majestic Turbo rebuild 3-4 years ago back in when I noticed a couple problems - The blow-off valve on the front of the turbo was remounted on the wrong side, and the orientation of the exhaust side is completely wrong. Seeing as it's been well over two years I don't think I can call them and complain...
Anyways, I think I can fix the valve, and I think I can fix the exhaust housing as it looks like it just clamps down on the side, but I just wanted to confer with all of y'all's expertise! Thanks!
1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman
jason c
PostPosted: Tue Sep 16, 2014 3:24 pm    Post subject: Reply with quote
Yes, both sides can be indexed. Leave both sides loose enough to turn. Tighten the hot & cold sections to the center section last (after mount & manifold), this will keep everything from being in a bind and cracking the housing, manifold or studs.
PostPosted: Tue Sep 16, 2014 3:26 pm    Post subject: Reply with quote
Call Majestic and ask before you install that thing. . .it may have sat so long the seals will fail.
PostPosted: Wed Sep 17, 2014 9:06 am    Post subject: Reply with quote
yeah but .... kinda...
leave It loose (housings), then install it exhaust manifold-bearing housing bracket-intake housing to fuel dizzy in that order...
then tighten the turbo housing bolts that you can reach..
then you have to take it all back off again to tighten the rest of the bolts all the way around those housings unless you have some magic tool that can reach crazy places..
atleast, that's what I had to do..
80 Turbo - Slightly Modified
