ThomasJoseph315
Guest
PostPosted: Sat Sep 27, 2014 11:02 am    Post subject: ... Reply with quote
Last edited by ThomasJoseph315 on Sat Dec 12, 2015 6:00 am; edited 1 time in total
PostPosted: Sat Sep 27, 2014 11:28 am    Post subject: Reply with quote
Wheels off the ground car on stands, drivers side engine mount stand very loose from block.
PostPosted: Sat Sep 27, 2014 12:13 pm    Post subject: Reply with quote
^yup.
Leave the control arms on the car, pull the outer tie-rods and steering rack, drop the crossmember, etc.
Getting the heat shields loose to get at the passenger motor mount arm can be a lot of fun!
ThomasJoseph315
Guest
PostPosted: Sat Sep 27, 2014 12:36 pm    Post subject: Reply with quote
kcoyle
PostPosted: Sun Sep 28, 2014 6:02 am    Post subject: Reply with quote
Also the pan gasket has a bunch of pieces. I used the Rasta recommended products in the thread below successfully.
http://www.924board.org/viewtopic.php?t=39271&view=next&sid=e8f37bc319c2bb65d4cd184f8183c52e
PostPosted: Sun Sep 28, 2014 9:56 am    Post subject: Reply with quote
Personally, I'd pull the engine and do the gaskets and etc on the engine stand. You're not far from there and you can clean everything, etc.
