Bartolucci
Joined: 31 Jul 2013 Posts: 13 Location: Rochester, New York
Posted: Tue Nov 17, 2015 4:59 am Post subject: Help with headlight lift motor and switch! |
Hello fellow 924 enthusiasts,
I have opened a Pandora's box full of problems with my 77. It started when I accidentally bumped the light switch while working on the car. The headlights were prevented from opening by the bra I had on the nose. That burned up my headlight lift motor. I found a used motor, but it didn't work. Tried another used motor and that one didn't work. While messing around with it I blew several fuses. I decided to bring it to my local wrench and he fried the headlight switch. Now I need a switch and another motor and who knows what else.
I'm wondering what the compatibility is for the motor and switch. I found this online:
PORSCHE 944 83-91
PORSCHE 924 77-82
PORSCHE 924 86-88
Can anyone confirm that these years and models are compatible fit these parts?
Thanks _________________ 1977.5 924
Brocade red |
Posted: Tue Nov 17, 2015 5:06 am Post subject: |
Be careful. The early cars had the same plastic housing but a different pin-out, so I would not assume that the later switches will work *electrically* with your early car.
The best thing to do is to check what PET says about the part number and see if it's actually the same or where the split on part number might occur. I suspect somewhere around 1979-80 based on what I've seen in my early vs. late cars. _________________ erstwhile owner of just about every 924 variant ever made |
kcoyle
Posted: Tue Nov 17, 2015 7:15 am Post subject: Re: Help with headlight lift motor and switch! |
| Bartolucci wrote: | The headlights were prevented from opening by the bra I had on
giggity giggity  _________________ 1982 931- Stock with MBC at 8psi
Bartolucci
Posted: Tue Nov 17, 2015 9:55 am Post subject: Re: Help with headlight lift motor and switch! |
| kcoyle wrote: | | Bartolucci wrote: | The headlights were prevented from opening by the bra I had on
giggity giggity  |
I just knew someone would bite on that one.  _________________ 1977.5 924
Brocade red |
Joined: 29 Jul 2001 Posts: 9138 Location: Royal Oak, MI, USA
Posted: Tue Nov 17, 2015 11:11 pm Post subject: Re: Help with headlight lift motor and switch! |
| Bartolucci wrote: | | kcoyle wrote: | | Bartolucci wrote: | The headlights were prevented from opening by the bra I had on
giggity giggity  |
I just knew someone would bite on that one.  |
PHRASING!!! _________________ Vaughan Scott
Posted: Tue Nov 17, 2015 11:56 pm Post subject: |
Are we still doing phrasing? _________________ Toofah King Bad
Bartolucci
Posted: Wed Nov 18, 2015 5:53 am Post subject: Re: Help with headlight lift motor and switch! |
| 924RACR wrote: | | Bartolucci wrote: | | kcoyle wrote: | | Bartolucci wrote: | The headlights were prevented from opening by the bra I had on
giggity giggity  |
PHRASING!!! |
*Context* my dear Watson: "The headlights were prevented from opening by the bra I had on the nose. "
BTW - Thanks Ideola for the suggestion re: the PET numbers. I was able to search for the part and found one at Auto Atlanta for a mere 17.00. Now all I need to do is find a compatible, working lift motor. (And, hopefully, I don't have any hidden wiring issues.) _________________ 1977.5 924
Brocade red |
Posted: Wed Nov 18, 2015 6:09 am Post subject: |
Hopefully your product actually shows up from Auto Atlanta.
Personally, I'd have bought from AutoHausAZ or another vendor, but I wish you luck. _________________ Stefan
