GAZ coilovers to suit 931
slpdesign99
PostPosted: Wed Dec 10, 2014 6:23 pm    Post subject: GAZ coilovers to suit 931 Reply with quote
Looking at these for a street some track 931. What are they like and will these fit with the steel rear arms?
http://gazcoilovers.com/porsche-924-gaz-coilover-kit-p-209.html
Scott (slpdesign 99)
1982 Porsche 924 Turbo
1964 Saab 96 Sport Replica
2008 Renaultsport Megane Team F1 R26
2006 Jeep Grand Cherokee SRT8
1990 Daihatsu Charade GTti Tarmac Rallycar
1979 Volvo 242GT, 4.2l V8
leadfoot
PostPosted: Wed Dec 10, 2014 11:44 pm    Post subject: Reply with quote
http://www.924board.org/viewtopic.php?t=33019&sid=21cd6c67e3739e75b1f3366293c6fbcf
google advanced search is your friend...
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
slpdesign99
PostPosted: Fri Dec 12, 2014 11:16 am    Post subject: Reply with quote
Stu
Thanks Leadfoot. I have read the post's just no one other than Carrera RSR mentions about the GAZ for 924 and he is using custom 944 ones!
PostPosted: Sat Dec 13, 2014 2:59 am    Post subject: Reply with quote
They are very track orientated. Perfect for hooning on smooth surfaces, can be a chore at low speed on rough roads. Rears need the thumb screws being swapped out for flat head screws and the steel arms need a hole cut in them for screwdriver adjustment. They are 924 turbo/early 944 fitment with 944 race valving, so may be stiffer than stock, but GAZ will valve to your requirements when buying direct or via a good reseller. Originally set up to be resting on the torsion bars with helper springs on the rear GAZ. Now set up resting in the GAZ springs with the torsion bar as a helper.
slpdesign99
PostPosted: Sat Dec 13, 2014 7:17 am    Post subject: Reply with quote
Thanks Careers RSR that sounds great. Here is Australia we have a scheme where if your car is 25 years or older you can register it for the road on a 45 90 use at a massive discount. This is my plan so having stiff suspension not going to be to much of an issue in my world 😃
Pumba
PostPosted: Fri Dec 19, 2014 3:44 am    Post subject: Reply with quote
Based on my experience - I would change to aluminum wishbones ( late 944's ) and then GAZ Gold Coilovers. And I'd go for removal of the torsion bars.
Way more space, removing weight from the rear axis, ability to change ride height easily.
MikeDanger
PostPosted: Fri Dec 19, 2014 7:15 am    Post subject: Reply with quote
I've read they aren't much lighter. can you verify?
It was either this or a giant box of legos
PostPosted: Fri Dec 19, 2014 9:04 am    Post subject: Reply with quote
Doing this pushes the hubs outboard and limits wheel choice. Ally trailing arms have been known to fail versus early steel when tracked hard. Most 924 944 968 race cars retain the torsion bars versus loosing them. Certainly in the UK race series
PostPosted: Fri Dec 19, 2014 10:09 am    Post subject: Reply with quote
Rear trailing arms aren't, but they are stronger until they break.
Front arms are perhaps slightly lighter, but rebuilding the ball joints is about $200/pr versus the $35 of the steel arms and they are also prone to cracking and failure on track cars where as the steel arms can be boxed and reinforced with some welding.
If you're going to go to the hassle, might as well get some aftermarket tubular control arms that are rebuildable/repairable and less prone to crack.
Pumba
PostPosted: Fri Dec 19, 2014 4:54 pm    Post subject: Reply with quote
I ment that the whole rear suspension weighs less when you remove the t-bars ( reducing unsprung mass ). Also, you can cut off rear supports of the torsion bar tube ( with steel trailing arms I even had to do it to fit GAZ coil-overs )
When using steel trailing arms there is a problem with GAZ shock regulation system. It is covered by the shock support. Also - the spring if you go coil-over runs very close to the trailing arm ( in my case it was even scratching it ).
EDIT: Of course, if you have a custom solution, these problems may not occur.
PostPosted: Fri Dec 19, 2014 7:24 pm    Post subject: Reply with quote
Gaz supply offset bushings to avoid fouling when asked. They will supply a rear strut with screw adjustment so once the steel trailing arm has an access hole drilled in its super easy to adjust. On a narrow body 924 I would stick with steel arms. On a wide body car ally may be a help with wider wheels to fill the arches. Torsion bars may be added weight but they work well in conjunction with coil overs.
Pumba
PostPosted: Fri Dec 19, 2014 9:26 pm    Post subject: Reply with quote
Hmm... Also, if you only add a coil-over, you will not have a thick spring...
I had 300lbs on the beginning ( with t-bars removed ) and that was probably maximum to avoid collisions between the spring and the trailing arm. Now, with 500lbs it is worse. That is why I'm changing steel to aluminum trailing arms.
In that case the only thing left speaking against keeping t-bars is height regulation, that is up to you.
PostPosted: Sat Dec 20, 2014 12:28 am    Post subject: Reply with quote
Keep in mind the torsion bars are still part of the unsprung weight and they are lower in the car so there's no change in center of gravity compared to adding larger coil springs to the rear shocks.
Also some have reported that excessively heavy coil spring/damper rates can crack the upper shock mounts, so you might plan on bracing the upper and lower mounts.
If you want to reduce weight in the rear suspension, then you'll need to look at hollow torsion bars, lightweight axle shafts, etc.
