Porsche 924 N/A LSD fit 931?
slpdesign99
PostPosted: Mon Dec 22, 2014 5:43 am    Post subject: Porsche 924 N/A LSD fit 931? Reply with quote
I have found a 1977 Porsche 924 N/A with an LSD. Is it possible to fit this in my 931?
Are there and difference or things I should look for ask owner?
Scott (slpdesign 99)
1982 Porsche 924 Turbo
1964 Saab 96 Sport Replica
2008 Renaultsport Megane Team F1 R26
2006 Jeep Grand Cherokee SRT8
1990 Daihatsu Charade GTti Tarmac Rallycar
1979 Volvo 242GT, 4.2l V8
leadfoot
PostPosted: Mon Dec 22, 2014 8:12 pm    Post subject: Reply with quote
No, you have a 25mm driveline, you want to go for either a g31 with lsd (very rare) or source a 944turbo box. A 944 box will work but is not as strong as the turbo box,
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
slpdesign99
PostPosted: Mon Dec 22, 2014 9:23 pm    Post subject: Reply with quote
Stu
Thanks suppose a quaife is the best option then!
PostPosted: Tue Dec 23, 2014 1:08 am    Post subject: Reply with quote
The diff might swap over, but you'll likely want to refresh the box and diff since you'll need to set the lash, etc.
Raceboy
PostPosted: Tue Dec 23, 2014 5:20 am    Post subject: Reply with quote
The diff will not swap over, they are completely different.
G31 also accepts 915 and 930 diff, but 915 diff has to be fine spline unit (meaning 1976 or later iirc). Coarse spline diff would fit if modified but that is too much for most.
But I would surely be interested in the 924NA diff.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Tue Dec 23, 2014 6:36 am    Post subject: Reply with quote
Crap, sorry I forgot that the ROW 931 had the dogleg 915-based box. Too used to the US.
So, never mind. Carry on
v8carreragts
PostPosted: Tue Dec 23, 2014 8:44 am    Post subject: Reply with quote
Only the 79-80 US cars have the G31. 81-82 US cars have the AUDI 016 so the diff might swap. The 77 has a 4 spd and has a designation of 088 so i am not sure that they will swap. Your list shows 82 931 so you have the AUDI unit unless someone replaced everything with the G31.
2015 AUDI Q7
2013 Chevy Cruze
slpdesign99
PostPosted: Tue Dec 23, 2014 9:03 am    Post subject: Reply with quote
Thanks for all the advice. Yes my car is a Australia Delivery 02/1982 build with the dogleg 5 speed gearbox.
What's the best way to check which gearbox/diff I have?
PostPosted: Tue Dec 23, 2014 10:06 am    Post subject: Reply with quote
Build tag in the trunk and there should be a code stamped on the transaxle case
v8carreragts
PostPosted: Tue Dec 23, 2014 11:52 am    Post subject: Reply with quote
I didn't notice where you were from.
Here is where the G31 S/N is:
2015 AUDI Q7
2013 Chevy Cruze
Raceboy
PostPosted: Tue Dec 23, 2014 11:25 pm    Post subject: Reply with quote
4spd diff is interchangeable with Audi 016 5spd diff, btdt.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
