gegge
Posted: Sat Dec 13, 2014 8:54 am Post subject: AFR at WOT for 924 NA |
Does anyone have a AFR graph going from 3000 to 6000 rpm?
Measured wideband or other accurate method please.
If I assume 14,7 at steady state after warm up, guessing not completly wrong. _________________ Carl Fredrik Torkildsen
Min
Posted: Sat Dec 13, 2014 11:50 am Post subject: |
My 924 NA responded the best when i set it to approximately 13:1 afr at WOT
gegge
Posted: Sat Dec 13, 2014 7:44 pm Post subject: |
Yes, the response improved when I dropped the pressure from the WUR. Could be like carb acc. pump effect wetting the inside of the inlet, but not improving power.
But I think that I am missing the stock numbers. Is the AFR constant over the revrange? By how much is it dropping when flooring the pedal? _________________ Carl Fredrik Torkildsen
Posted: Sun Dec 14, 2014 2:11 am Post subject: |
I'm running my NA race car at 12.8. It's slightly better than it used to be at 13.1 based on my configuration (stock cam, 9.5:1 compression and header).
YMMV. _________________ 1979 924 NA race car H-Prod SCCA
gegge
Posted: Sun Dec 14, 2014 4:25 am Post subject: |
I have this dyno graph, but canīt remember where I got it. Guessing someone here at 924board provided it:
AFR at 12.0 is not bad at all, but dropping down to tenish @ 7000 rpm needs to be rectified. _________________ Carl Fredrik Torkildsen
gegge
Posted: Fri Jan 02, 2015 7:53 am Post subject: |
found another one:
