chris79
Posted: Fri Jan 09, 2015 5:04 pm Post subject: poor performance |
| After so many jobs my engine work, though the performance is poor, comes around 140 km / h , then loses power, why ? |
Posted: Fri Jan 09, 2015 5:42 pm Post subject: |
What do you mean looses power at 140? Does it loose a lot of power or it just does not pull that hard anymore? Is it a turbo or a NA?
Check AFR and timing first.
Check compression second.
If it revs at 140 but does not go, check clutch for wear. _________________ Supercharger and EFI kits
chris79
Posted: Fri Jan 09, 2015 6:36 pm Post subject: |
| It's aspirated 924 of '79 , after about 140 km/h there is no more power, I found a lot of fuel in the motor oil, but I think because I tested injection whit engine off and fuel pump active. |
Posted: Fri Jan 09, 2015 6:45 pm Post subject: |
Then change the oil NOW, otherwise you damage the engine...running with too thin oil.
Check fuel mixture, get a lambda probe and set the mixture using that.
Also get a timing light and check if the ignition timing is set right.
While you do that, check that the engine timing is also right, rotate the crank until the signs match and check if the cam sign is also matched. _________________ Supercharger and EFI kits
Posted: Sat Jan 10, 2015 2:41 am Post subject: |
Check fuel pump volume per FSM, check for vacuum leaks. _________________ Toofah King Bad
chris79
Posted: Sat Jan 10, 2015 7:36 am Post subject: |
| Do you know amount of flow in one minute for each injector ? |
Posted: Sat Jan 10, 2015 7:41 am Post subject: |
Should be in the Haynes manual. What color are the spark plugs? _________________ Supercharger and EFI kits
chris79
Posted: Sat Jan 10, 2015 8:10 am Post subject: |
I haven't found in Haynes,
spark are white color |
jason c
Posted: Sat Jan 10, 2015 8:52 am Post subject: |
| morghen wrote: | | Should be in the Haynes manual. |
There is no spec for amount, only that they be even or within a % of each other. The amount varies based on plunger position. Since plunger position varies per car, no spec is given for amount. |
Posted: Sat Jan 10, 2015 3:51 pm Post subject: |
Not so. Fuel pump volume/min is specified in FSM. _________________ Toofah King Bad
chris79
Posted: Sat Jan 10, 2015 6:17 pm Post subject: |
what's FSM ?
I'm in Italy, I don't know. |
Posted: Sat Jan 10, 2015 6:30 pm Post subject: |
| chris79 wrote: | | what's FSM ? |
Factory Service Manual. _________________ 78 924 NA
5-lug |
chris79
Posted: Sat Jan 10, 2015 6:35 pm Post subject: |
| translated in units of measurement? |
Posted: Sat Jan 10, 2015 6:48 pm Post subject: |
Fuel pump should supply >= 750 cc in 30 seconds (after fuel filter, before fuel distributor).
Fuel pump current draw should be <= 8.5 amps. _________________ 78 924 NA
5-lug |
chris79
Posted: Sat Jan 10, 2015 7:06 pm Post subject: |
| ok, but if possible I want to know flow of injectors, because the pump is new and I suppose flow is correct. I want to check if fuel distributor is ok |
