clutch for high power
alperx
PostPosted: Sun Jan 25, 2015 8:57 am    Post subject: clutch for high power Reply with quote
hi,
my transmission is 5-speed with 13/16" input, 24 teeth spline.
my car is now gonna be painted and I the engine and transmission is out, too.
my pressure plate and clutch is this :
when I check the numbers on pressure plate, it is from Renault 21 ))
clutch disc seems OEM Sachs.
is this the correct pressure plate ?
I search internet, and it shows me a different kind of pressure plate as this one :
PostPosted: Sun Jan 25, 2015 5:25 pm    Post subject: Reply with quote
Your pressure plate looks right.
alperx
PostPosted: Sun Jan 25, 2015 8:48 pm    Post subject: Reply with quote
I need to change it, what do u recommend for high torque turbo applications ?
Shurick
PostPosted: Sun Jan 25, 2015 9:31 pm    Post subject: Reply with quote
I use SPEC stage II clutch kit in my car: http://www.specclutch.com/cars/Porsche/924/1980/Single
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
alperx
PostPosted: Tue Jan 27, 2015 7:29 pm    Post subject: Reply with quote
do you have the "actual" photo of your pressure plate ?
