Qik Nip
Posted: Sat Jan 31, 2015 5:47 am Post subject: Need help: Shifter ball socket bushing 79 NA |
Guys:
I need to replace the (disintegrated) cup bushing on my shifter linkage. To clarify, I need the bushing that's inserted in the rod that's attached to the shifter's base at the front and to the ball located at the rear of the torque tube. It functions as the pivot for the shifter and is anchored to that ball on the TT.
I believe the transmission is referred to as the 016. (It's the five speed that has first gear located to the left and back (where 1st gear would be on a three speed floor shift), with reverse directly above it).
I've spoken to Pellican and they can't seem to identify the bushing PN.
Rick _________________ '79 NA 924 Land Speed Car
Bonneville G/CPRO record @ 149.825MPH
Arkansas Mile G/CPRO record @ 138.0 MPH
Great Lakes SCCA SM points champion '09,'10,'11 |
Posted: Sat Jan 31, 2015 8:07 am Post subject: |
The part you are looking for is in illustration 701-00, 924_79 catalog. . .#22. _________________ Toofah King Bad
Power Tryp
Joined: 16 Apr 2009 Posts: 435 Location: Calgary, Alberta
Power Tryp
Posted: Sat Jan 31, 2015 8:12 am Post subject: |
Uhh crap Rasta and I chose different parts... _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
Qik Nip
Posted: Sat Jan 31, 2015 8:45 am Post subject: |
Thanks guys. Part ordered. There went another $56 bucks. Gotta car builds. This is why you can buy a used race car for less that it costs to build one!
jason c
Posted: Sat Jan 31, 2015 10:38 am Post subject: |
| The last time I changed one I used a new bushing in the old socket. It was a 914 part number iirc, I don't have it handy. |
jason c
Posted: Sun Feb 01, 2015 12:44 am Post subject: |
I thought the socket I used was a 914 part number, I can't find it. I did find a socket which appears to be the correct size but it has a 911 part#.....911 424 139 00
It is approximately 23.5mm in diameter & 23.75mm long. |
