924 carrera GTS breather question
Dutch924-racer
PostPosted: Tue Jan 27, 2015 6:55 am    Post subject: 924 carrera GTS breather question Reply with quote
The GTS has a crankcase breather on the valve cover. Does anybody know what Porsche did with the breather on the side of the block ?
http://cdn6.vierenzestig.nl/wp-content/uploads/2014/12/924-gts-clubsport-6882.jpg?379f39
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
knobby
PostPosted: Sun Feb 01, 2015 5:26 am    Post subject: Reply with quote
Although both cars have the breather outlet in a slightly different location it would seem to me that they are venting the valve cover via an AOS and dumping into the inlet although I cant make out exactly where in the inlet wether its going to the intake air filter box (as on my 1981 931 S2)or what.
That said I would like to know why and how that affects the turbo oil drain vent which goes to the side of the cylinder head in the valve chamber?
Is this a mod which could benefit all 931's?
81 RED 931 S2(daily driver),81 WHITE 931 S2(not currently drivable).
Cincinnati,Ohio
PostPosted: Sun Feb 01, 2015 8:58 am    Post subject: Reply with quote
You have been on this quest for awhile now!! Doing some searching, haven't seen any definitive answers for you.
http://www.924board.org/viewtopic.php?t=38872&highlight=924+gts
pcelenta
PostPosted: Mon Feb 02, 2015 12:06 am    Post subject: Reply with quote
which white GTS is that in the photo? is it chassis number 001? or 93A0150562? I know it is not 011 because that one had a TMIC.
Harm
PostPosted: Mon Feb 02, 2015 5:09 am    Post subject: Re: 924 carrera GTS breather question Reply with quote
GTS chassis 001, engine bay (back in 2006)
Source: http://www.finecars.cc/en/detail/car/4756/index.html
pcelenta
PostPosted: Mon Feb 02, 2015 6:24 am    Post subject: Reply with quote
Harm...you are the best! looks like photos taken at springbok...oh...and do you know which is parked right next to it??? 93A0150562! the GTS prototype!
mark911rsr
PostPosted: Sat Feb 14, 2015 1:08 am    Post subject: Reply with quote
I can shed some light on this for you.
On my GTS , the crankcase breather has been capped off , as has the lower inlet to the breather 'canister' , as you can just about see in these pictures ( it's not the easiest position to get a decent photo ! )
My car was dry- sumped at the factory , hence no requirement for a breather on the crankcase as the scavenge pump pulls it back into the tank.
However I guess on the non dry sump cars , there would be a hose between these 2 outlets.
Hope this helps
Cheers
Mark
leadfoot
PostPosted: Sat Feb 14, 2015 9:27 am    Post subject: Reply with quote
nice1 thanks for sharing this...
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
