Fuel accumulator cross refernece part #? (79)
sciroccosteve
PostPosted: Sun Mar 15, 2015 4:24 pm    Post subject: Fuel accumulator cross refernece part #? (79) Reply with quote
PO epoxied mine.
Rockauto has one for around 110ish
Seems foolish to me. Any advice to find it cheaper?
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns
leadfoot
PostPosted: Sun Mar 15, 2015 5:51 pm    Post subject: Reply with quote
Yes... this one I'm selling...
http://www.ebay.com.au/itm/161636355961?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
brian19600
PostPosted: Sun Mar 15, 2015 7:58 pm    Post subject: Reply with quote
Here is one on ebay that supposedly fits a 79:
http://www.ebay.com/itm/NEW-BMW-Fuel-Injection-Fuel-Accumulator-0438170007-320i-/121569865944?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1979
Still a bit pricey.
Harm
PostPosted: Mon Mar 16, 2015 1:51 am    Post subject: Re: Fuel accumulator cross refernece part #? (79) Reply with quote
…the larger ones are even double the price, but at least you'll just need one.
You might consider changing to a single unit and take up Stu's offer.
Some cross reference:
The small 20cc unit (you'll need TWO) came on the early Toofahs pre ~1980.
Art. Nr.: 0438170007
EAN: 3165142833521
Katalog NR: 0 438 170 007
BMW : 16 12 1 118 899
CITROËN : 1560 09
CITROËN : 79 10 032 367
FORD : 1562372
FORD : H75TM 9K044 CA
PEUGEOT : 1560 09
PEUGEOT : 7910 032 367
PORSCHE : 477 209 083
VOLVO : 1266224
VOLVO : 1666224
BMW 3 (E21) 318 i 77 11/1979 08/1982
BMW 5 (E12) 518 i 75 08/1979 08/1981
PEUGEOT 505 (551A) 2.0 TI,STI 81 08/1979 10/1986
BMW 3 (E21) 320 i 92 06/1975 08/1982
VOLVO 240 (P242, P244) 2.1 Turbo 114 08/1980 07/1984
VOLVO 240 Break (P245) 2.1 80 08/1980 07/1984
VOLVO 240 Break (P245) 2.1 Turbo 114 08/1980 07/1985
VOLVO 240 (P242, P244) 2.1 90 08/1974 07/1980
VOLVO 240 Break (P245) 2.1 90 08/1974 07/1979
BMW 5 (E12) 520 i 92 10/1975 05/1977
VOLVO 240 (P242, P244) 2.3 103 08/1978 07/1980
VOLVO 240 (P242, P244) 2.3 100 08/1980 07/1983
VOLVO 260 (P262, P264) 2.7 103 08/1974 07/1980
VOLVO 260 Kombi (P265) 2.7 103 07/1975 07/1982
PORSCHE 924 2.0 92 11/1975 08/1989
PORSCHE 924 2.0 Turbo 125 11/1978 06/1980
The larger single unit on the later Toofahs.
Art. Nr.: 0438170024
EAN: 3165142430089
Katalog NR: 0 438 170 024
PORSCHE : 931 110 140 00
bis Baujahr: 06/1985 | ab Baujahr: 01/1976 | ab Fahrgestellnummer: 92491 00001 | Porsche 924 -- 2.0 1975/11-1989/08 1984 ccm, 92 KW, 125 PS
ab Baujahr: 07/1980 | bis Baujahr: 06/1981 | … … … … … … … … … … … … … … … … … Porsche 924 -- 2.0 Carrera GT 1980/06-1986/10 1984 ccm, 154 KW, 209 PS
ab Fahrgestellnummer 92491 00001 … … … … … … … … … … … … … … … … … … … … … Porsche 924 -- 2.0 Turbo 1978/11-1980/06 1984 ccm, 125 KW, 170 PS
bis Baujahr: 06/1984 | ab Baujahr: 07/1980 | … … … … … … … … … … … … … … … … … Porsche 924 -- 2.0 Turbo 1980/06-1986/10 1984 ccm, 130 KW, 177 PS
Source:http://www.teilehimmel.de/shop/0438170007631881-detail
I've always wondered if the accumulators on the 1.8+ VW engine's that use K-Jetronic could be used.
Do you happen to have any info on that?
Kind regards,
Harm.
Edit01: Line 5; 40cc should read 20cc. Altered.
sciroccosteve
PostPosted: Mon Mar 16, 2015 3:31 am    Post subject: Reply with quote
I have also wondered if one from a 1.8 vw kjet system would work, as a buddy has a few of them.
2000 V6 Passat
C. Montgomery Burns
PostPosted: Mon Mar 16, 2015 4:16 am    Post subject: Re: Fuel accumulator cross refernece part #? (79) Reply with quote
Rockauto has one for around 110ish. Seems foolish to me
Smokin' deal on a critical component. Foolish is betting on a used one to last in the long term, IMO.
Harm
PostPosted: Mon Mar 16, 2015 5:54 am    Post subject: Re: Fuel accumulator cross refernece part #? (79) Reply with quote
VW's accumulator:
Things looked promising until I came across this image^
Note there are two different threads on there…
Vfour83
PostPosted: Sun Mar 29, 2015 8:47 pm    Post subject: 477-209-083 Reply with quote
OEM Number 477-209-083 can be one of two Bosch models. Many suppliers are vague or incorrect with the years they are suitable for.
My '78 924 is a 438 170 015 unfortunately i ordered a replacement based on a suppliers information and received a 438 170 007.
Has anyone found if there is an adapter to go from the larger thread on the 007 model to convert to the smaller thread size? Also what type or description are the fittings they use?
If not i have a 438 170 007 available for sale.
brian19600
PostPosted: Mon Mar 30, 2015 10:51 pm    Post subject: Reply with quote
Did you check with these guys:
https://www.belmetric.com
sciroccosteve
PostPosted: Mon Apr 20, 2015 1:17 am    Post subject: Reply with quote
So I was sent a Bosch 0438170007, the one with 2 different sized fittings on top, and a nipple on bottom.
It appears to be the 20cc one/VW one.
Before I return it, is there a way to utilize it?
I am assuming not. Bosch currently has none of the 40ccs available according to my supplier, so if I cant get this one to work, I will have to buy used.
2000 V6 Passat
C. Montgomery Burns
Harm
PostPosted: Mon Apr 20, 2015 2:41 am    Post subject: Re: Fuel accumulator cross refernece part #? (79) Reply with quote
In my first reply I made a typo in line 5:
It said 40cc where it should have the amount 20cc.
My apologies if my mistake set you in the wrong direction, Steve.
Kind regards,
Harm.
sciroccosteve
PostPosted: Mon Apr 20, 2015 5:56 am    Post subject: Reply with quote
Its all good. wasnt you who steered me wrong.
2000 V6 Passat
C. Montgomery Burns
