Turbo Rebuild
nickthompson
PostPosted: Mon Apr 06, 2015 3:05 am    Post subject: Turbo Rebuild Reply with quote
Has anyone attempted to rebuild their own turbo? I'd like to rebuild mine but having done is not in the budget.
scriblz7
PostPosted: Mon Apr 06, 2015 3:10 am    Post subject: Reply with quote
http://924board.org/viewtopic.php?t=27972
the second thread in the how to section
Riley
79 924 n/a with gt body
15 VW GTI
jason c
PostPosted: Mon Apr 06, 2015 1:30 pm    Post subject: Reply with quote
What kind of turbo & what's wrong with it?
nickthompson
PostPosted: Mon Apr 06, 2015 4:11 pm    Post subject: Reply with quote
Ko3, nothing is wrong with it. I would just like to have it refreshed as it came off a 189k mile engine.
jason c
PostPosted: Mon Apr 06, 2015 6:25 pm    Post subject: Reply with quote
You shouldn't have a problem. Make sure you index everything (especially the impeller to the shaft) & make sure everything is within tolerance (especially the thrust).
skytrooper
PostPosted: Tue Apr 07, 2015 12:01 am    Post subject: Reply with quote
I did my own complete turbo rebuild. It is not all that difficult, the hard part , for me, was getting the turbo back into the car.
If you index properly when disassembling (photos are a good idea, too), it will make the reassembly much easier. I used a lathe and dial indicator to check the shaft run-out, and also to spin it after assembly. The turbo worked fantastic after the rebuild.
The reason I had to rebuild mine was that the PO dropped one of the ducting screws into the cold side , and didn't bother to go after it. I guess he realized his mistake after the vanes were ground off. He couldn't figure out why it ran so poorly and had no power.
http://www.924board.org/viewtopic.php?t=24670&highlight=
Matt
1987 - 924S "Black Pearl"
1982 - BMW 633CSi
1984 - BMW 528e
1983 - 944 N/A "Blue Max" (Gone)
1981 - 931 "Scarlet Harlot" (Gone)
1976 911S Targa (Gone)
