Ignition coil test 924 2.0 1984
RobertN
PostPosted: Wed Apr 22, 2015 12:55 am    Post subject: Ignition coil test 924 2.0 1984 Reply with quote
Hi Guys
Whilst I'm waiting for my alternator to be refurbed and my attempt to remove starter motor as the wires are fried ( previous post! ) is on going! Can anyone advise if the test for the ignition coil is okay? As follows:-
Voltage test ignition on.
Term 15 to ground 6.7v
Term 1 to ground 1.4v
Resistance test:-
Term 1 to 15, 1.3 ohm
Term 1 to 4 , 8.88 kohm
Robert
Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders.
jason c
PostPosted: Wed Apr 22, 2015 10:17 am    Post subject: Reply with quote
It is a little outside of spec but that doesn't necessarily mean its bad. You could bench test it....
RobertN
PostPosted: Wed Apr 22, 2015 6:34 pm    Post subject: Reply with quote
Thanks Jason... ill see how things go with alternator and starter motor/wires. Just trying to cover all bases!!
Robert.
