Rear brake adjustment screw 924 1984 na
RobertN
PostPosted: Sat May 09, 2015 3:20 am    Post subject: Rear brake adjustment screw 924 1984 na Reply with quote
Hi guys, just looking to adjust my brakes. I cannot see the adjustment screw on the back plates? Can anyone enlighten please?
Thanks.
Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders.
Spliffy
PostPosted: Sat May 09, 2015 3:48 am    Post subject: Reply with quote
The adjuster is accesed via a hole on the backplate looks like a cog and can be rotated with a screwdriver. IIRC its at the bottom of the back plate but its been a while since I did mine.
1983 N/A
Turbo front brakes
Teledials
Audi T/B
Flush fit screen
RobertN
PostPosted: Sat May 09, 2015 4:25 am    Post subject: Reply with quote
Thanks. I can see 3 rubber plugs. I believe one might be for inspecting the shoe wear! I'll take them off any see if I can get at the cog.
Thanks.
Robert.
RobertN
PostPosted: Sat May 09, 2015 5:40 am    Post subject: Reply with quote
Removed the rubber plugs and can see the cogs on both recesses but no actual screw head to fit driver into.
Robert.
PostPosted: Sat May 09, 2015 6:33 am    Post subject: Reply with quote
Stick a flat screw driver into the cog and pry up or down on the screw driver to adjust the brakes.
RobertN
PostPosted: Sat May 09, 2015 7:24 am    Post subject: Reply with quote
Thanks Stefan. I'll try that.
Robert.
Raize
PostPosted: Sat May 09, 2015 9:27 pm    Post subject: Reply with quote
They should be easy to turn. If they're stuck, you need to take the drum off and clean up the threads and re-grease them. don't try and force them as you'll ruin the backing plate. Ask me how I know.
PostPosted: Sun May 10, 2015 1:28 am    Post subject: Reply with quote
+1, pop off the drum and inspect/clean/lube the components. It will also help you visualize how the adjustment process should go.
