Posted: Thu Mar 19, 2015 4:04 am Post subject: Need 931 S1 piston options |
Howdy folks. I'm contemplating a project on a 1980 931. I'm interested in freshening the motor but, surprise surprise, pistons seem to be somewhat unobtanium.
I've read a zillion threads and it looks like there are options out there. But none of them have specifics on part #'s, sources or costs. So I'm hoping you can help me out.
Goals: I don't want to do anything fancy necessarily. Probably about 1.0 bar. Cometic gasket. Reusing the stock rods and crank. No head studs, just bolts. Intercooler. Stock CIS. Cost is important. Reliability as well.
What are my options regarding the following approaches to replacement:
Stock - Mahle?
Stock-ish - essentially stock piston, but from somewhere other than Porsche/Mahle
Light performance upgrade
VW flat-top
Actual part #'s and sources are what I'm after. I will consider purchase of new or used from an individual if someone has something on the shelf they want to sell (or trade! I have lots of cool toofah stuff). I'd also be interested in hearing your personal experiences, good or bad, especially if there's something that really did NOT work out
What say ye? |
WEASEL149
Posted: Thu Mar 19, 2015 4:40 am Post subject: |
Stock cast 931 pistons are too expensive, difficult to find and by many accounts, not very strong.
If I were you I'd contact EBS and get a set of JE pistons. Ask them if they can get them made with a crown dish of at least 40cc or preferably 45cc to keep CR around stock.
They normally sell them with a 22mm wrist pin but also sell small end bushes at around $10 each.
I think the pistons were $650 last time I asked.
Your problem then is obtaining rod bolts. ARP for stock rods normally requires a group buy and they're not cheap compared to off the shelf ARP2000 bolts.
I'm currently having some sample rods made by a friend of mine that take 3/8" ARP bolts but they'll take a while as he's making them 'on-the-side' where he works and there are about 70 production stages. _________________ 1979 UK 932 |
WEASEL149
Posted: Thu Mar 19, 2015 4:45 am Post subject: |
If you can stretch to the Crower I-beam rods that Ideola offered I'd go for a set of those.
They're immensely strong and I've seen them used a lot in tractor pulling etc. with very high horse power and torque. _________________ 1979 UK 932 |
Posted: Thu Mar 19, 2015 4:56 am Post subject: |
Good info, thanks.
But with Ideola no longer in the trade, who would be the best source for the Crower rods?
Also, that kind of still leaves me with the rod bolt problem, doesn't it? Or do the Crower rods take a stock ARP bolt of some sort? |
Posted: Thu Mar 19, 2015 5:05 am Post subject: |
New rods will come with matched bolts.
Another option but may be pricey for US is Mittelmotor in Germany. Off the shelf parts and proven performance and reliability. Pistons, rods, gaskets, bearings etc. etc. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
WEASEL149
Posted: Thu Mar 19, 2015 6:25 am Post subject: |
| emoore924 wrote: | Good info, thanks.
You may be able to approach Crower direct?
They will come with their own reusable rod bolts. _________________ 1979 UK 932 |
Harm
Posted: Thu Mar 19, 2015 5:34 pm Post subject: Re: Need 931 S1 piston options |
1 Vatican Euro (EUR) is equal to 1.06 United States Dollar (USD)
…could be helpful  |
Posted: Thu Mar 19, 2015 11:42 pm Post subject: |
Fwiw, some have expressed concerns about je piston material with cast iron blocks. The theory is they need to start a little loose to make up for their expansion, and this can lead to piston slap.
My motor has probably 10k on it at this point, and I can hear a little slap when cold. Probably won't hurt anything...probably. But it can weaken and break skirts. _________________ Toofah King Bad
Posted: Fri Mar 20, 2015 12:15 am Post subject: |
| Quote: | | 1 Vatican Euro (EUR) is equal to 1.06 United States Dollar (USD) |
Well, when the pope starts selling pistons and con rods, that will be a very important exchange rate to know  |
Posted: Fri Mar 20, 2015 3:15 am Post subject: |
| Rasta Monsta wrote: | Fwiw, some have expressed concerns about je piston material with cast iron blocks. The theory is they need to start a little loose to make up for their expansion, and this can lead to piston slap.
My motor has probably 10k on it at this point, and I can hear a little slap when cold. Probably won't hurt anything...probably. But it can weaken and break skirts. |
Same issue for all forged Pistons? I had a conversation with my builder regarding my Omegas. Loose and suffer a little slap or tight and risk grabbing and scuffing. Take your pick!! _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
WEASEL149
Posted: Fri Mar 20, 2015 10:18 am Post subject: |
Its the 2618 forged alloy that can suffer from piston slap at cold.
Best thing to do with 2618 pistons is buy them with anti scuff skirt coating. This allows you to run a bit tighter clearance safely. The Omegas have it.
Alternative is order 4032 forged which doesnt need as much clearance.
Emoore - approach JE directly. You can then specify exactly what you want and get them made for the stock 24mm wrist pins (which I believe the Crowers were made for IIRC) _________________ 1979 UK 932 |
Posted: Fri Mar 20, 2015 11:51 am Post subject: |
| Anyone know about or have used the VW flat top pistons? If so, what's your experience, what are the specs/part #'s for what you're using and where did you get them? |
Kenodog
Posted: Tue Mar 24, 2015 7:52 am Post subject: |
I have a set of the Gene Berg special VW 88mm low compression flat tops in my new motor. The compression calculator says they should yield about 8:1 which is perfect for me. The are the Cima / Mahle 'forged' pistons,(which are really hypertectic cast) should be good as they were made for forced induction motors. They make the engine non interference as well which is a HUGE bonus. Won't be able to tell you they real skinny on them however until I get my bloody car back from the shop !
Leigh _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
leadfoot
Posted: Tue Mar 24, 2015 9:52 am Post subject: |
| emoore924 wrote: | | Anyone know about or have used the VW flat top pistons? If so, what's your experience, what are the specs/part #'s for what you're using and where did you get them? |
yes PM sequential for details....
http://924board.org/viewtopic.php?t=21138&highlight=pistons
carbon fiber GT mish mash
Posted: Tue Mar 24, 2015 10:49 am Post subject: |
I found something (sorry, IDK how to link to the exact page). If I enter "88mm piston" into the search feature at the top of the page here:
https://www.actionimport.com/
I find three sets of EMPI VW pistons; one 85.5mm, one 87mm and one 88mm.
So I'm thinking the 87mm set would work with little or no machining for the stock block and the 88mm would work if you punch it out.
Any thoughts on (a) appropriate machining, or (b) rings?
Edit: Looks like sequential was banned a long time ago so other sources would be welcome.
Thanks!!
