Euro Bumper Bits - Need Help
PostPosted: Mon Mar 16, 2015 2:38 am    Post subject: Euro Bumper Bits - Need Help Reply with quote
Need help with bits 11 and/or 11a in the below capture from the 85 PET:
This weird little gem is basically an adapter that allows the light to be mounted in the 924 bumper. They use the same light in the 944 without an adapter.
If someone could post detailed pics and/or measurements, I am trying to evaluate whether one could be easily fabricated. Apparently they are different right to left.
PostPosted: Mon Mar 16, 2015 6:46 am    Post subject: Reply with quote
IIRC they are a rubber bit for looks only. Could be wrong, haven't had mine off for awhile.
the screw 14 comes in from L or R depending on which side of the car.
Harm
PostPosted: Mon Mar 16, 2015 7:38 am    Post subject: Re: Euro Bumper Bits - Need Help Reply with quote
Besides looks (it covers four screws) these weird little rubber gems have the difficult task to defend the lenses from obstacles that want to harm your precious…
I have spares and could post detailed pics and measurements (metric) of this in 24hrs.
Cheers.
PostPosted: Mon Mar 16, 2015 4:01 pm    Post subject: Reply with quote
OK, I can see 11a as a trim piece, but 11 must be part of the aux light mounting.
PostPosted: Mon Mar 16, 2015 4:46 pm    Post subject: Reply with quote
I'm working on refurbishing the front bumper of my 931 so i've just last night looked at these parts.
11 is a rubber trim piece with a screw trough its side and a metal strip/clip inside(13) used on euro models.
11a is a part for the cars that came with bumper shoks...so i guess US models. You dont need 11a, you need 11 for your euro look bumper.
Shurick
PostPosted: Mon Mar 16, 2015 4:47 pm    Post subject: Reply with quote
Haven't seen a Euro 924 with a part listed as 11a. PET lists it as M058 option or a part of it. Don't know what that option code means.
Part #11 is a little rubber piece that covers aux light and turn signal mounting screws. It mounts directly on a #9 (you can see a mounting hole) with a screw #14 and clip #13.
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
Harm
PostPosted: Mon Mar 16, 2015 11:59 pm    Post subject: Re: Euro Bumper Bits - Need Help Reply with quote
Some light on the buffers;
The two down are the opposite side.
Lenght: 8,4 centimeter
Width: 3,6 cm
Max hight: 2,7 cm
I'll put these in a drawing.
Ltr!
PostPosted: Tue Mar 17, 2015 1:19 am    Post subject: Reply with quote
Excellent pics. I'll look again at what I have.
Brockoli
PostPosted: Thu Mar 19, 2015 12:26 am    Post subject: Reply with quote
I was just looking for part #11 for my euro bumper.
I believe 11a was for cars shipped to Japan (I think...). I thought 11 just screwed into the side of the driving light and wasnt used to mount the light.
I talked to a wrecker in England about shipping but never pursued the pieces. Anyone have any #11's for sale?
PostPosted: Mon Mar 23, 2015 11:18 pm    Post subject: Reply with quote
OK, still working through this. . .
Can somebody with a ROW 924S check their bumper and see if this part is there? It is NOT in the PET.
Raceboy
PostPosted: Mon Mar 23, 2015 11:51 pm    Post subject: Reply with quote
11 is present on all euro 924's, not just S. It is just screwed onto the hi-beam light and may provide some protection against breaking the glass if you hit something but the mounting tab will surely break sooner on the light itself because it is made of some soft silumin or similar.
Never seen 11a.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Brockoli
PostPosted: Tue Mar 24, 2015 7:37 am    Post subject: Reply with quote
O ya I forgot. That bumperette with the two bolt holes is the 924S ROW. Heres a pic I found when I was trying to figure out what those were.... dont know if this helps
Shurick
PostPosted: Tue Mar 24, 2015 8:17 am    Post subject: Reply with quote
Raceboy wrote:
Never seen 11a.
+1
Lookig at the front valance it's a picture of 944.
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Tue Mar 24, 2015 9:53 am    Post subject: Reply with quote
Don't think so. 944 has a plastic frame piece around the lights. The picture matches the 11a from the PET illustration.
v8carreragts
PostPosted: Thu Mar 26, 2015 2:00 pm    Post subject: Reply with quote
I have #11 on mine. They look better than 11a. I bought mine from a yard in the UK. I just e-mailed them with what I wanted and they shipped it to me here in the states.
They are what Harm has in his picture. I believe they fit early 924's.
2015 AUDI Q7
2013 Chevy Cruze
