Suplementary Start Valve picture required please
924aussie
PostPosted: Mon Aug 15, 2011 1:16 pm    Post subject: Suplementary Start Valve picture required please Reply with quote
Has anyone got a picture of the wires as they are connected on the start valve , just want to check mine , this is only on some models . I am after the other side to this image
Alan
green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold
Muz924
PostPosted: Mon Aug 15, 2011 8:59 pm    Post subject: Reply with quote
Hi Alan,
Is this what your after ? This is from my 1980 Aussie Spec.
From above......
From Below....
Cheers
Santo
1978 924 RoW 5-Speed (Current Project)
1980 924 RoW 5-Speed (Donor Car)
1985 Alfa Romeo Alfetta GTV 2.0 (Previous Project Car)
924aussie
PostPosted: Mon Aug 15, 2011 9:15 pm    Post subject: Reply with quote
Thank you, it appears that the yellow with red trace is more to the centre of the valve and the brown white is closer to the edge or is it just an optical illusion
Is there anysort of writing on the bottom of the valve that is covered up by the muck on mine ?
I am soaking the screw thread in WD40 now so that I can take it out, it is a bit tight in there at the moment and as it is connected to other fuel components I dont want to force it
Alan
PostPosted: Tue Aug 16, 2011 3:11 am    Post subject: Reply with quote
ewww yuk
PostPosted: Tue Aug 16, 2011 8:57 am    Post subject: Reply with quote
I dont think polarity is an issue with these solenoids.
Muz924
PostPosted: Tue Aug 16, 2011 10:40 am    Post subject: Reply with quote
[Alan
No writing on the bottom of mine. Looks like both spade connectors are equally located on bottom. The brown on mine just looks closer to edge as both connectors are bent. Don't want to touch them as they will most likely fall off!
I just replaced them as I found them which is not necessarily the correct combo, although matches up with the way the wires hang.
924aussie
PostPosted: Tue Aug 16, 2011 9:58 pm    Post subject: Reply with quote
OK I have unscrewed it and cleaned it up a bit.
FYI Mine has the following information on it
Pierburg 7.20525.01
Germany
12v 9250
another discussion on the forum lists a
Electric Solenoid: Pierburg 7.20525.01 12V 1328
Alan
924aussie
PostPosted: Thu Aug 18, 2011 10:40 am    Post subject: Reply with quote
Correct me if Iam wrong, which is usually the case, but doesnt a solenoid do something like open and close ?
If the wireing is the wrong way around would not the solenoid open when it should be closed and close when it should be open ?
Alan
staticsan
PostPosted: Thu Aug 18, 2011 11:50 am    Post subject: Reply with quote
Solenoids are just electro magnets. Energise them and the bolt moves.
It is possible for a solenoid to move the bolt in the other direction if the coil is energised in reverse, but it is just as possible for the bolt to move in the same direction whichever direction. From what people are posting, I'd say the SSV is of the latter type. The symmetrical connections also suggest that.
Wade.
ryanspud
PostPosted: Wed Jun 10, 2015 11:58 pm    Post subject: Reply with quote
Hey guys, I just seen this thread and the electric solenoid show in the pictures earlier is exactly what I am looking for.
Anyone has an idea where I can buy one ? My 1985 924 needs a replacement of it.
THanks[/quote]
Fifty50Plus
PostPosted: Thu Jun 11, 2015 2:05 am    Post subject: Reply with quote
That's the frequency valve which usually has up to a 50% duty cycle to adjust the mixture based on feedback from the oxygen sensor to the computer.
We have been able to modify our computer on the race car to drive the frequency valve between zero and over 80% if needed to achieve 12.8 CO readings throughout the rev range.
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
Harm
PostPosted: Thu Jun 11, 2015 4:04 am    Post subject: Reply with quote
Sorry, Chuck. That is not the US frequency Valve;
It's the ROW Solenoid Valve to help cure the hot start problems on the later cars.
@ ryanspud: Could you add type and year to your signature, and confirm what you have is a ROW 924?
Maybe you should try getting your hands on a second hand one by putting an add up in Cars and Parts Wanted/For Sale
Harm.
ryanspud
PostPosted: Wed Jun 17, 2015 10:33 pm    Post subject: Porsche 924 1985 2.0Litre Reply with quote
Hey @Harm,
Hey my Porsche is a 924 model with a 2.0litr engine standard, manufactured in 1985.
The part I need is this one in the link below :
https://www.dropbox.com/sh/mga63qp7f6181o0/AABZ2kudAeguOsDdiKnbMiFVa?dl=0
What do you mean by ROW 924 please ?
Harm
PostPosted: Thu Jun 18, 2015 5:10 am    Post subject: Re: Porsche 924 1985 2.0Litre Reply with quote
…so it was ment for the Rest Of the World since the US stopped taking in 92fours as soon as the 94fours came into the picture (1982).
ROW : Rest Of the World
A ROW 924 wasn't intended for the North American continent, in short US (My apologies to Canada)
The US 924 is different to a ROW car…
in looks and engine.
Harm
ryanspud
PostPosted: Fri Jun 19, 2015 6:27 am    Post subject: Reply with quote
Thanks for the information @Harm. Any ideas of where I can find the part I'm looking for, second hand or new ? Porsche shop does not have it for sale and to be honest I'm running out of options as I got no replies from some scrapyards and distributors I contacted.
