davethehypnotist
Posted: Wed Jul 29, 2015 6:09 am Post subject: Are my tie rods bad or are they loose |
GBot a tie rod issue.
Are they bad?
Watch this really short :43 video
https://youtu.be/sZlxe5n1yTU |
JL91
Posted: Wed Jul 29, 2015 6:34 am Post subject: |
The shaft is meant to rotate a bit as its a ball joint. To test if a track rod end has gone, jack up the vehicle grab the wheel at 3 and 9 and rock it backwards and forwards(towards and away from you), if there's any knocking or clunking or play in the track rod end then its worn.
Similar to how you check to see if a wheel bearing has play in it (But you grab it at 12 and 6 instead)
You will feel the knock/play in the track rod if there is any, |
snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Wed Jul 29, 2015 7:16 am Post subject: |
the shaft shouldn't be turning freely like that
normally the big bolt near the tire on the shaft is made to tighten the tie rod end to the shaft....
you will need to tighten the nut and the tie rod end together in order to stop it from moving.
Tie rod end needs to follow the tie rod movement. _________________ 1979 924 NA |
jason c
Posted: Wed Jul 29, 2015 10:07 am Post subject: |
The twisting you're showing is completely normal, it is a ball & socket design (just like your shoulder). However, it looks at the beginning of the video you are able to get some in/out, side to side movement- that is not normal.
The proper procedure for testing the tie rods is to grab the wheel at the 9 & 3 plo'clock positions & wiggle the wheel side to side like you're turning the steering wheel right-left-right-left just a little bit. You will be able to feel the play. You can also look at the joint while you do it, if there is play (movement on one part of the joint but not the other), the joint is bad. |
maybeoneday
Joined: 09 Dec 2013 Posts: 82 Location: Melbourne, Australia
Posted: Tue Aug 04, 2015 6:11 pm Post subject: |
| jason c wrote: | | The twisting you're showing is completely normal, it is a ball & socket design (just like your shoulder). However, it looks at the beginning of the video you are able to get some in/out, side to side movement- that is not normal. |
I second that, going from the movement between 0.06 and 0.13 in the video tie rod end ball joint looks like it has far too much play. The rest of the video looks normal yes the shaft should be able to rotate a little. run the check jason and JL are suggesting thats the correct way to debug this one. _________________ 1977 924 NA Auto |
davethehypnotist
Posted: Sat Aug 08, 2015 12:03 am Post subject: Better look at the test you guys suggested. |
I jacked up the car and did the test. Here is the video of the results. Looks like they are both bad but could the inners just be loose?
I think I may have to remove the boot to actually find out.
https://youtu.be/8Jfoj99Hcpg
Video is just over a minute. |
maybeoneday
Posted: Thu Aug 13, 2015 6:01 pm Post subject: Re: Better look at the test you guys suggested. |
| davethehypnotist wrote: | I jacked up the car and did the test. Here is the video of the results. Looks like they are both bad but could the inners just be loose?
I think what u are calling the inners is the steering rack?? I am thinking that probably a new rack is in order, its a little hard to tell though and would like to hear other opinions before you went out and replaced it. If it is movement in the rack the tie rod ends are probably shot too and I would think better to replace both but again other opinions first. _________________ 1977 924 NA Auto |
Posted: Thu Aug 13, 2015 11:43 pm Post subject: |
The inner and outer tie-rods are available from parts houses and are fairly easily replaced.
The rack's internals do wear, but there is a pretension bolt to help take up slack from wear. If the wear is too much, then the internals need to be rebuilt/replaced.
The U-joints are also wear points, they are harder to service though as you have to send the entire shaft to a company in the US to replace them. _________________ Stefan
davethehypnotist
Posted: Tue Jan 19, 2016 5:36 am Post subject: The skinny on the tie rods |
I took one side off and took a look at the tie rod. The outer are fine. The inners are really loose. Should these be covered in grease? They aren't. I'm thinking about just packing them with grease and putting them back on. I ordered a replacement from the parts store that were for a VW rabbit of the same year as this board says they were exact replacements and they aren't they are the correct size but 2" too short so I sent them back.
So the question is my fellow 924 enthusiasts. Are the inner tie rods supposed to be packed in grease. It seems as though they were and the grease just wore away. It's only been 32 years since they were serviced so what say you. Pack them? Physically they look perfect just loose. |
Posted: Tue Jan 19, 2016 6:32 am Post subject: |
Replace them. _________________ Stefan
