new problem k-jetronic
chris79
PostPosted: Mon Jan 18, 2016 8:00 am    Post subject: new problem k-jetronic Reply with quote
today my engine crackles in acceleration and performances are poor over 140 km/h.
Pression and control pressure are good, my injectors and o-ring are new, but after I turn off engine there is a leak in control pressure circuit, this value go zero in few seconds.
Clackling seems due to injectors, but how is possible ?
Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro
chris79
PostPosted: Mon Jan 18, 2016 11:45 pm    Post subject: Reply with quote
color of spark plugs:
https://lh3.googleusercontent.com/lf54wJhqgKf4GqnpyhYaXVZXzrqqU-mgnSqz1AeMgVHGFYp05dKIa1_7RQ4JDJbmKE-j=w1366-h768-rw-no
https://lh3.googleusercontent.com/AKskFRmECkB6NgkPvEoYi3EFjqZNsi2Mk4P3y9W7Da3PLa7TsG5YaRTer96D9_aOdoxI=w1366-h768-rw-no
loss of power is over 3000rpm, but engine rumble even under 3000, the day before the engine run well to almost 200 km/h.
I don't understand if the problem is electric or it's a lack of fuel.
chris79
PostPosted: Tue Jan 19, 2016 2:54 am    Post subject: Reply with quote
I solved problem, electrode of first cylinder was bent, and is not the first time.
gerben1986
PostPosted: Tue Jan 19, 2016 3:31 am    Post subject: Reply with quote
How is it possible that it bend???
911SC - 1980
chris79
PostPosted: Tue Jan 19, 2016 3:56 am    Post subject: Reply with quote
I don't know but this is photo of my spark plug:
http://lh3.googleusercontent.com/Q6FlqpjU3Nv2R1_ccppaf0twb8La9rm-wCboIBZfYWKMDH2uBsG5b51Dk3nGi5OI1JBH=w1366-h768-rw-no
chris79
PostPosted: Tue Jan 19, 2016 6:51 am    Post subject: Reply with quote
I solved the mystery, the sleeve of first injector is broken , then mixture on this cylinder is lean, temperatore is too high and this bent electrode.
