4-lug to 5-lug
chris79
PostPosted: Tue Apr 18, 2017 6:06 am    Post subject: 4-lug to 5-lug Reply with quote
I need some informations about this conversion, if I use 931 as donor car it's enough to buy disks and calipers?
Or it's necessary to replace even front and rear hub?
Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro
PostPosted: Tue Apr 18, 2017 7:32 am    Post subject: Reply with quote
Yes, you'll need the hubs front and rear...
hdrider19
PostPosted: Tue Apr 18, 2017 11:02 am    Post subject: Reply with quote
Here is a link to a very complete 5 lug conversion on this site.
http://www.924board.org/viewtopic.php?t=27357
87 924S
chris79
PostPosted: Tue Apr 18, 2017 6:59 pm    Post subject: Reply with quote
I think this parts are necessary from 944, from 931 I think hub was the same of 924 na.
PostPosted: Tue Apr 18, 2017 9:48 pm    Post subject: Reply with quote
Yes and no. Yes, if you just buy the 944 parts, that's most of what you need.
The correct distinction is not 931 vs 924 vs 944 hub, but 4-lug vs. 5-lug hub. 931s came with both - M471 aka 5-lug was an option on both NA and Turbo 924.
chris79
PostPosted: Tue Apr 18, 2017 10:15 pm    Post subject: Reply with quote
Then I need minimum of parts showed in the link?
PostPosted: Tue Apr 18, 2017 11:51 pm    Post subject: Reply with quote
Do read through the thread; as Rasta noted, it's not actually necessary to change the rear trailing arms, just to replace the drum backing plate (the stamped steel plate that the drum brake components mount onto) with the aluminum caliper mounting plate for the 5-lug setup (which both mounts the caliper to the trailing arm, and mounts the components for the drum parking brake).
Not swapping the trailing arm will save you a lot of work...
chris79
PostPosted: Wed Apr 19, 2017 1:23 am    Post subject: Reply with quote
Then I have not to replace hubs?
PostPosted: Wed Apr 19, 2017 8:23 am    Post subject: Reply with quote
Read this: http://www.924board.org/viewtopic.php?t=27357
PostPosted: Wed Apr 19, 2017 1:35 pm    Post subject: Reply with quote
Too much trouble.
Would rather ask.
chris79
PostPosted: Wed Apr 19, 2017 3:34 pm    Post subject: Reply with quote
I read many times this thread, but this conversion is from 944, I don't understand if conversion from 931 need even replacing hubs or they are the same of na.
924-76
PostPosted: Wed Apr 19, 2017 9:14 pm    Post subject: Reply with quote
You should read it again because all your questions ask in the tread are answer there.
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
PostPosted: Thu Apr 20, 2017 6:24 am    Post subject: Reply with quote
Of course, I could understand some reluctance to read the whole thing, every bloody word... given English as a second language...
Sometimes it's helpful to ask, if you think your question isn't answered, even if it is... may just not be easy to understand...
PostPosted: Thu Apr 20, 2017 6:28 am    Post subject: Reply with quote
In Europe 931 and 944NA brakes are identical, so are the hubs and suspension...with one small difference...the 944 does not have that hole trough the spindle for the speedometer to work.
Why not buy a 931 or a 944..?
PostPosted: Thu Apr 20, 2017 6:33 am    Post subject: Reply with quote
morghen wrote:
Why not buy a 944..?
Exactly.
